Question about Home
I shut my water off for a few days and since turning back on the water pressure is low. Only a small amount of water coming out of faucet.
  • 2,382 Answers
Hi, low water pressure in a faucet can be caused by clogs, corrosion in the pipes, or delivery pressure from the main source. Identifying the problem will help greatly in the actual repair.
Check out the aerator screen on the faucet spout by unscrewing it from the end of the faucet to see if it's clogged, if it is not, the the problem is from the source...
Posted on Sep 10, 2010
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I can't get a water flow from my RO faucet or from the water dispenser in the door of the fridge...also the ice maker won't work. I just replaced the 3 large filters, and no change. Just a trickle, then...
If the tank is full of water (pick it up) with 8 lbs of air then the air charge is low and little or no water will come out. Take should have 7psi air pressure when it is completely empty. Make sure all the water valves are on. If feeding RO with piercing valve make sure it is open all the way and has plenty of water pressure feeding RO. If there is no water being created then there will be no water at faucet, fridge or ice maker, assuming they are all tied into the RO.
RJ
Mar 31, 2011 | Culligan Under Sink Water Filter
Just lost pressure. Only a very small stream of water comes out, hot or cold. All other faucet in the house work fine. It is about 1 1/2 years old. R10433-CP
First try the tip ariator. it can plug up. then you have to check the inlet system, which includes shut off valves, hoses to the faucet and the cartridge. It is the cartridge that has the small openings, but shut off valve seat material falls back into the feed channel. I usually remove cartridge, cover with a towel and turn on feed water briefly. Often I get little pieces.
Oct 27, 2010 | Kohler Model 10433: Fort® Single-control...
The code is f 20
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks.
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Apr 01, 2010 | Whirlpool GHW9100L Front Load Washer
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Hot water tap - no pressure and splutters
Do you have your own hot water tank? or is there one serving many units? There is a 'dip tube' in hot water tanks, if it gets old it sometimes deteriorates and small parts of plastic get loose and will float around in the tank, if a piece finds it way up to the outlet then that might explain why you are getting the low water pressure. one wat to check is to twist off the aerotor on the end of your faucet, if there are any small pieces of white plastic then you will have to replace the dip tube and maybe even flush out the tank. it is also possible that a piece of plastic has traveled up the water line and it stuck in the faucet cartridge.
Feb 11, 2009 | Stone Plumbing
Vaillant Mag 325 warm water only full pres. cold low pressure
you need a certain amount of water pressure for the water heater to turn on this is actaully one of the biggest problems that all manifactures forgot to tell anyone it is normal for the computer to shut down beings it is designed to heat water at a fast rate when you turn the water down, it's not enough pressure for for sensors to turn on to heat the water so turn on the spigot a little more and enjoy
Jan 26, 2009 | Water Heaters
Low water flow from kitchen faucet
Their is likely rust build up behind the valve connections to the hot and possibly cold water supply lines. Turn the water off to the house relieve the pressure and remove both valves. Once removed use a screwdriver to break up the rust. With a small bucket under both lines turn the water main back on slightly to clear rust. Replace both valves with new ones.
Jan 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
