Question about Foxconn (945G7MA-8KS2) Motherboard
Hi shut down my pc went to turn it on and would not turn on the led on the motherboard is red is that normal
    Scholar:
  • 105 Answers
Hi. i had that problem. it happens in many foxconn motherboards. all you have to do is\
---Buy a UPS, otherwise you will have problems.
remove the power cable that comes from POWER SUPPLY to the MOTHERBOARD.
put back the power supply cable to the motherboard.
fix all cables correctly. then you may start the computer.
GOOD LUCK.
Nuno ----- nunex2@yahoo.com
Posted on Nov 11, 2010
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
Optiplex 330 wont turn on shut down went to power back up won't do anything no fans only light is the led on motherboard
your powersupply could of gone bad try to unplug the powersupply and plug it back into the motherboard if this doesnt stop it the part of the powersupplly that tells it to kick on is bad
Dec 12, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
My desktop PC is a Gateway GT5656. The power
Could be try putting your power LED on your HDD LED header on your mainboard and then look at this while booting up and this will tell you if its the LED or the Header on your mainboard
May 03, 2009 | Gateway GT5654 Desktop PC
Motherboard wiring
Green/wht normally = Reset or Power LED
Red/wht normally = HDD LED
And is the third red/BLACK?
There should be a label on the black pin jumper at the end of each wire.
Does it say anything?
Jan 16, 2009 | E-Machines eMachines Desktop PC
LAPTOP NOT TURNS ON
This is probably due to a bad battery or damaged powerjack. Does the laptop work when connected to a plug point?
Sep 28, 2008 | Computers & Internet
Power start up itself after 10 mins
Check you start up settings it may be set to start from keyboard mouse or modem plus others even in the BIOS
Aug 08, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
Foxconn (945G7MA-8KS2) Motherboard Logo
75 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
