Question about Sony Playstation 3 (PS3) Console
Playstation doesn't turn on. beep, then yellow flashing light, then 3 quick beeps. Disc is inside, cannot get it to eject.
    President:
  • 1,139 Answers
Sadly this is what is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps, thanks for using FixYa
Posted on Oct 16, 2010
PS3
In my experience there have only been 2 issues that caused it to beep 3 times. First if you try to eject a disc and there is no disc inside it will do that. Secondly if the PS3 crashes it will beep 3 times and shut off. Typically turning it back on will work but in some cases a yellow light will show up that people refer to as the yellow light of death (YLOD). If that happens your PS3 needs repaired. You can send it to Sony and they will charge you a ton unless it's under warranty still, or you can find a private person or company to replace it. If you go the cheap route be advised that most places will not guarantee they can fix it and Sony won't touch it once it's been opened. Good luck!
Apr 24, 2013 | Sony Playstation 3 (PS3) Console
When turning on my console it wont fire up or eject the disc that is in the machine the Standby light flashes, beeps and then nothing ?
Maybe you have the "yellow light of dead"
You should let it repair, your console is broken.
try putting it in recovery modeHow to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
When you try to turn on the system, it beeps twice and then flashes red, but does not turn on. You can't even eject the disc.
Yellow light of death. Here is my step-by-step instruction link.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
The PS3 works fine but freezes in career mode of MLB 10 The Show. Is this also an over heating issue?
It doesn't sound like an overheating issue, more of either a disc read issue or firmware issue.
Please try my following tip for re-installing the firmware. If this does not fix it then try cleaning the laser lens.
Failing that, if it is an overheating problem usually it will tell you with an onscreen prompt or shut down with a flashing yellow light
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says
Hopefully this will cure the problem on its own.
Hope this helps
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
Flashing red light will not eject game
if you turn it on, and it goes green then yellow then beeps 3 times and flashes red, then your ps3 has overheated and been damaged. you can fix it with the heat gun trick, http://www.youtube.com/watch?v=4_Ic1_TY-GU
but it will only break again.
try flipping the switch in the back, then hold the eject button while you flip the switch back on, that should eject the disc.
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
MY CD WILL NOT EJECT FROM MY PLAYSTATION 3 AND THE LIGHT BLINKS GREEN THEN YELLOW FOR A SECOND
you are a victim of the dreaded yellow light of death my friend your options are limited the console is fixable but not easily yellow light is a critical hardware failure the disc hopefully not important is possible to retrieve by putting the blu-ray rom from your console into another console to eject it
due to your yellow light problem i think ths recovery menu is a shot in the dark but 1 try cant hurt ok hope this helps
Nov 17, 2010 | Audio Players & Recorders
When i try to turn on the system i get a yellow light then it beeps twice and the light flashes red and it wont turn on or eject my game ive tried holding down the disc eject for 10 seconds and nothing is...
turn off your ps3 to then just press and hold the eject untill the disc comes out as for the ylod you need to replace thermal paste on the gpu and cpu goto llamas.com to see tutorials and try pulling hard drive out and resetting it back in place
Oct 13, 2010 | Sony Playstation 3 (PS3) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 not working
You'll have to contact Sony for repair. I would highly recommend you NOT trying to fix this problem yourself.
You can reach Sony at 1-800-345-Sony
Or google: rescuetechla for my blog page on some common ways to fix the problem. (most of them won't work for most consoles, but if you want to try, you're more than welcome.)
May 11, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
