Question about Kenmore Washing Machines
Not spining properly leaves water in clothes - Kenmore Washing Machines
  • 714 Answers
Clutch could be slipping not getting the full spinout
Posted on Sep 11, 2010
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a Siemens Washing Machine and when I try to wash my clothes there is a power cut in my apartment. The spining functionality works without any problem. I also notice that I can do the washing with...
You need to replace the element, it is defective. When you wash with cold water the element does not turn on, but as soon as you use hot water, the element would need to go on, then it comes into contact with water and "click" goes the power.
Hope this helps
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 03, 2011 | Washing Machines
The machine is not spining properly and leaving wshing wet
when machine is empty turn on side and check underneath for slipping or broken belt Replace . hope this helps
May 17, 2010 | Washing Machines
I have a kenmore elite washing machine. it is not spining the clothes all the way. it is leaving the clothes soaking wet.what should i look at
Take the agitator apart by pulling off the softener cup and taking out the bolt, probably broken plastic DOGS. Ask your appliance parts guy for them.
Nov 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
My washer wont empty out while spining.
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Aug 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
