Question about Hitachi 120GB Hi-Speed Mobile Disk USB 2.0 External (EXTMD120) Hard Drive
I have a Hitachi Simple Drive Mini x 320 GB that I've been using as an external for my macbook pro. I have been using it without problems for over a month now, but last week it didn't eject properly from my laptop and now whenever I try and connect the external it says that it is drawing too much power from the USB port and the computer will not recognize it. The port itself is fine and this issue has never come up before. I have tried everything I can think of on the apple side of the issue and I am beginning to worry that the external may just be fried. Is there anything I can do that I am overlooking, perhaps changing to a firewire connection or something so that I can still use it?
  • njjeffries Sep 10, 2010
    yeah it does have a y-cable and it does the same thing when you plug it in
    President:
  • 2,571 Answers
Does the usb cable you are using have 2 usb plugs so you can plug it into 2 usb ports at the same time.
If not, you could try using one, sometimes my external HD will not work on some pc's if i just plug it into 1 port
Posted on Sep 10, 2010
Macbook hard rive replacement
Check out the website ifixit.com for good step-by-step instructions on how to replace the hard drive in your particular MacBook!
Apr 23, 2014 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
How do you use the simpletech 160 gb ext drive with a macbook pro or a macbook
Your external HDD must be MAC OS compatible.
I've it is compatible, just plug it in and it should pop-up
Jun 08, 2011 | SimpleTech SimpleDrive 160 GB External USB...
I have a 320 Simple Tech 320GB with nothing on it and am trying to do a back-up 87 GB in size and it keeps telling me I do not have enough room?
Hello, thanks for using FIXYA,
have you had try to format the external drive, do that then try to copy again.
Let me know if that works
Thanks
Rate this solution please
May 27, 2011 | SimpleTech Signature Mini 320GB External...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Hitachi Simple Drive mini 500 GB USB only ticking sound when plugged in. Eight months old, used sparingly. Any ideas?
The external storage device has several major components:
* USB cable
* external power-supply (your "mini" device may not need one)
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 04, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
My hitachi 320GB external hard drive is not mounting on my macbook (mac os x 10.5) and is not even found in disk utility.
When this happens, usually the drive is a total loss. You can check this by connecting to a USB to hard drive dongle, and connect to a windows PC, IF it works here you may simply need to reformat back on the Apple. If it doesn't then the drive is bad.
Mar 16, 2010 | Hitachi Travelstar 7K320 HTS723232L9A360...
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
Simple tech mini 320 gb external hard drive
It mostly comes with 3 years of warranty but you cant utilise warranty just for being "not recognized".
Try to trouble shoot the problem by using the technical suppport offered for the item
Apr 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Apr 21, 2018 | VIA Computers & Internet
See all Hitachi 120GB Hi-Speed Mobile Disk USB 2.0 Questions
Computers & Internet Logo
280 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
