Question about GE JBP68 CleanDesign Electric Kitchen Range
Surface unit light is one all the time - even with all burners off
    Genius:
  • 1,416 Answers
What this indicate or what it means is that there has been a loose of wire connection from the element or weakness from the element
What you will have to do first of all is to unscrew the oven from the stroll with a screwdriver (technician tools ) the trace the wire down to the element (heater or heat provider) it is silver in colour at the lift or right Conner side of the oven to see if there is any form of loose of wire from the connection ,If any then fix it up to the element , but if non then it meant that the element is bad which will need a replacement .
You can get the element from the below site
/www.maxoncorp.com directcaterparts.co.uk premierrange.com appliancedirectparts.com
All these site offer good service and price you can go shopping
Please note if you which to get the element your self make sure it same size from the weak or old one to avoid incompatible with the the panel .
Thank you and thanks for using fixya.
Posted on Sep 11, 2010
Surface unit light stays lit. even when burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Aug 04, 2011 | Kenmore Kitchen Ranges
Right front hot srface indicator light is always on even if the stove has been off for days.
If the switch or sensor to the burner in question has a short in it, this can happen. Normally this does not cause a problem with the functionality of the unit nor operation. To call someone out to open the oven at this time could be costly for the hunt for the short could take time. The light is powered from the burner sensor under the cooking surface.
I hope this helps..
Jul 15, 2011 | GE Ovens
Surface unit control problem
The burner element that is staying ON is also the same one causing the surface light to stay on.
The switch that controls the element is bad.
Unplug the range. Open the switch control console and replace the defective switch.
Make sure the range is unplugged because of high voltage in the console.
Jan 30, 2010 | GE JSP26 Electric Kitchen Range
This morning, I went to turn the oven on to preheat. The oven light came on, but when I passed 250 degrees, it went back off. I turned the knob around to broil, the light came on again. But the oven never...
Check the breaker pannel or fuse box. The elements work on 220 volts the lights on 120 volts. If this doesn't help repost and well try again
Hope This helps
Please leave feed back
Nov 29, 2009 | Kitchen Ranges
Burners are only lighting half way and then gas cuts out. Then the system repeats it' self. coleman heater mod #7995856, serial #1287658845. this is pretty close or just like heaters used in RV'S
OK, the burners will need to have flame on the entire surface or it will trigger a sensor and shut-off. Get a brush and maybe even one of thoes can of air and blow off the burner. Stay away from the glow ignitor because that is very delicate. Once you get flame on all surface of the burners, the unit should stay lit.
Oct 19, 2009 | Coleman Propane Forced Air Heater...
Surface unit indicator light is always on
One set of contacts in a surface unit switch is "welded" together, causing the burner indicator (pilot) light to remain on even when all burners are shut off.
With power disconnected to the range, remove the back cover behind the switches and pull one of the wires going from a surface unit switch to the indicator lamp. Make sure the bare wire is not touching anything and reconnect power. If the light goes out (and still goes on when the other burners are turned on) you found the bad switch. If light still on, repeat the procedure with another one of the burner switches (reconnecting the first) until you find which switch is the bad one. (most often it is the burner you use the most, generally the right front burner) If you post your full model number and tell me which switch it is, I can look up the part number for you.
Feb 06, 2009 | GE Kitchen Ranges
Hot Surface Light Stays On
you do have a top burner sensor that has failed. the hard thing is to figure out which one. most of these units have a 5 year part warranty, but you have to pay for an authorized servicer replace it for you.
if you want to figure it out yourself, you will have to find which of the wires, from the burner sensor, controls the indicator light. its not hard as it is usually the smaller one. each burner has a sensor and if you are certain you can work with the electricity on, its just a process of elimination.
unplug the unit from the wall, then take off the wire from 1 burner at a time, tape it off, to prevent shorting to ground, then plug back in and see if the light has gone out.
then you can order the new sensor, but on some models, you have to get the whole burner and sensor assembly.
Dec 28, 2008 | Maytag MER5775Q Electric Kitchen Range
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
GE JBP68 CleanDesign Electric Kitchen Range Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
