Your RF Module went bad, Its in the front, usually when a controller will not connect then it has to do with the rf module which is about ten bucks on ebay.
However its not common to have the video go out because of it,
You may need to send it back out to microsoft, how long ago did you get it fixed.
It was only a few months ago that I got my xbox fixed for the red ring of death. My Controller WILL turn on my xbox but it will not connect. Controller plugged in will also not connect. The xbox will turn on but will not boot up. =/
Sounds like there is a problem with one of the chips on the motherboard, I still however say that the rf module is def broken, and it will turn the system on, Because it uses the rf to turn on the system just like the remote but when using the buttons and analog sticks it requires the rf module.
I would also call microsoft and tell them you have the red rings again, and just send it in, they will fix it regardless
A little clarification . First when the ROL board aka RF board fails it will not except any
commands from the controller. So it's unlikely your RF board is bad. Second Auido with
no video is some what common and is caused by a open connection ( video feeds ) under the G.P.U. so the shop probably need to do a little more through reflow .
Just a little info
Rob
I FIGURED OUT THE PROBLEM!! It was nothing wrong with the xbox. I had been using a HDMI cable that had less wires to it. Not the original one it came with. This worked for a while. with a lot of testing of wires (And going plugging it in using my boyfriends wires to test) I found out that the xbox is finicky and wants the one it came with. Thanks to all those for your help.
SOURCE: 360 Xbox problem Three red rings
Unfortunately there is nothing that you can directly do to fix this problem.
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
SOURCE: XBOX 360 3 rings of death
i just got the 3 rings of death today and didnt get a warranty but i heard there was a 1 yr warranty on it
and if there isnt can anyone help me please ?
SOURCE: xbox 360 2 rings of daeth
Hello jbitwa,
See if this helps you. http://forum.teamxbox.com/showthread.php?t=472553
One red light signifies a major hardware failure or system error[4] , depending on which hardware failure or system error it is depends on how the problem can be fixed but in some cases there is no easy recovery and the console must be repaired or replaced. Two means the console is overheating and must be switched off and left to cool. Three, the infamous 'Red Ring of Death', means a general hardware failure and the console must be sent to Microsoft for repairs. All four red lights simply means that the console cannot detect its AV cable.
SOURCE: XBOX 360 FREEZES WITH OUT RROD?
your drive is out or fimware corrupted just check the hardware and flash your console
Oh, so I can say that I just have the red ring of death and they will just fix it? Will it be free since it was something they already had to fix recently? Because my warranty for the ring expired. And thank you for the info. =)
Okay. Thank you. There isn't any audio either, though. Literally, it turns on but doesn't boot. No one I ask in my dorm knows either, lol. So I'll have to call microsoft. At least I know the rf isn't bad.
