Question about ASUS Eee PC 900 Notebook
My problem is that the fuction key seems to be permanently pressed. In other words, I no longer access U I O P - I only get 4 5 6 *, and so on. Help!
    Scholar:
  • 119 Answers
Try cleaning around that key with a tooth brush and alcohol, I know sounds weird but works if its sticky,
Other then that there may be an issue with the keyboard and therefore you would have to get another one, That or use a external keyboard that has a usb port on it if your laptop does not have the regular port,
Also before any of that up there is your number lock key on?
Posted on Sep 10, 2010
  • elpi_gr2 Nov 20, 2010
    I have exactly the same problem and cleaning the keys didn't help at all. In addition when the number lock key is on, none of those keys work at all when they are pushed except P that gives * again. Some other keys have swapped with others i.e the .> key is now DEL for me. Can anyone tell me if that is something that the guaranty will cover so I will send it for repair?
How to find error codes
press the back key twice.
press back + enter at the same time.
type 9-4-2-8 (text the word "what")
then enter
press the faults soft key.
Mar 23, 2013 | TurboChef TORNADO Electric Oven
When sending a fax the pages do not go through the feeder until the connection with the recipient is made. Once made it pulls the papers one by one. It will not store and send. This was working fine up...
fax memory switched on documents held until other machine answers then transmits page by page fuction parameters of fax side of machine fuction 7 then 4 switch memory to on . the only other way the machine will send like this is by a manual dial when the hook button is pressed then the number put in the documents are held until the user is prompeted to press the start key
Oct 28, 2011 | Panasonic DP-8020E Black and White Copier
Having problem with ti 83 calculator everytime i graph it read error invalid dimensions
You must deactivate the statistical plots. If you do statistical graphs, the graphing is reconfigured in a way that happens to be incompatible with regular fuction graphs.
  1. To deactivate the statistical plots.
  2. Press [2nd][Y=] to access the (STAT PLOT) menu.
  3. Press [4:PlotsOff][ENTER].
  4. Calculator displays Done.
  5. You are ready to draw the function graphs.
Feb 15, 2010 | Texas Instruments TI-83 Plus Calculator
My k'board is not responding properly I have to hold the key down to get it to type a letter. Help. Each time a key is pressed it makes a ''blip'' sound also. Strangely the k'board worked fine when logging...
You need to turn OFF your Filter Key option for beeping key strokes.
1) Go to START > Control Panel > Accessibility Options
2) In the window Accessibility Options > select the tab Keyboard
3) Under frame FILTER KEYS, select button SETTINGS
4) In the window Settings For FilterKeys > under NOTIFICATION >
5) UNcheck "Beep when keys pressed or accepted".
Sep 25, 2009 | Computers & Internet
Hello, Kindly ineed your'Support ihave IBM Thinkpad Laptop keyboard function give output error i type u come output 4 wrong key fuction kindly ineed your;s help Thanks for your support with best regards,...
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Shift key plus the ScrLk (Scroll lock) key, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Jun 04, 2009 | IBM Thinkpad T43/p Notebook
Can not ger microsoft word to load it ask for product key and i got it and now it says it is invailad
True love,
Did you get Microsoft word/office installed with your PC? Or as a free download?
If so you likely have received what is called a "Trial" version. Which is only valid for a certain period of time. Once the time expires the want you to either pay for a permanent liscense or stop using the software.
If you believe you HAVE a permanent liscense, then you can contact Microsoft to clear things up and get an key to reactivate office. If it WAS a trial then you have 2 choices.
1.) Contact Microsoft to purchase a permanent liscense
2.) Get one of the "Free" office suites that are out there Suns "OpenOffice" seems to be one of the most popular of the free opensource office replacements and has just about every function that MS Office does.
Hope this helps you
Dave
Nov 16, 2008 | Gateway Computers & Internet
Programming feature access keys
These Keys may be set as line keys instead of feature access or not tagged as "feature access" in the programming, also you can only have so many feature access keys... 8 comes to mind but I could be wrong, some features can be programmed permanently onto a button in the main programming so you can free up some more feature access (user programable) buttons.
Jul 18, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Help
Web link with the manual is http://www.rcapearl.com/pdf/TH11xx_IB.pdf
If your lazy he's the cut and paste from the manual;
1. To start voice recording, press M twice to access the Home menu.
2. Press or to highlight “Voice Recording". Then press to advance. (thats the key you would press to skip ahead a song)
3. Press or to highlight “Record”. Then press to access voice recording
mode.
4. Press when the display shows “Ready” to start voice recording.
5. Press to pause record. Press again to resume recording.
I had a hard time myself with this fuction so don't feel alone. I used the voice record to record a lecture and it was surprising sensitive but then again I had the professer put it in is front shirt pocket. It would over modulate a bit but was audioable and served its fuction for me
RoB Goins
RobertGoins@hotmail.com
Nov 22, 2007 | RCA OPAL M4001 MP3 Player
ASUS Eee PC 900 Notebook Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
