Question about Toshiba 50H81 50" Rear Projection Television
Can't adjust red convergence down - Toshiba 50H81 50" Rear Projection Television
  • scn6438 Sep 10, 2010
    thank you i'll try that.
  • Toshiba Master
  • 11,800 Answers
In that case the the convergence board's circuit responsible for the red gun is faulty - and the rest aren't far behind.
Time for a full refit. For that use this repair kit.
http://www.tvrepairworld.com/toshiba_repair_kits
Posted on Sep 10, 2010
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
    If the following doesn't work the tubes could be at the end of life:
    Adjusting convergence:
    Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
    To adjust the convergence of the picture tubes:
    1. Press the 'MENU/SELECT' button on the remote.
    2. Press CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
    5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
    6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
    7. Press the 'EXIT' button to exit the menu.
    If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
    To Adjust multipoint convergence:
    2. Use CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
    5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
    6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
    7. Press the 'EXIT' button to enter ADJUST mode.
    8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
    9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
    10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
    11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
    12. Press CURSOR RIGHT to save the multipoint settings.
    13. Press the 'EXIT' button to exit the menu.
    Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
    http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
    The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
    Please rate my help++++Thanks for using FIXYA
    Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
    Blue convergence wont work
    This is a common problem. Your convergence has gone out.
    Common symptoms are...
    1) 3D Video
    2) Warped Video
    3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
    Go here for a solution...
    http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
    Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
    Remote will not adjust red convergence/multi-point horizontally
    check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
    Jan 17, 2009 | Philips 55PP9352 55" Projection Television
    No color adjustment
    Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
    i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
    can't magic focus
    Posted by avatar13.jpgejaparks on Mar 03, 2011
    AdChoicesMajor Appliance Repair
    www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
    Get $75 of Advertising
    www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
    Solutions (1)
    Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
    Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
    Red convergence will only move up or down
    Stk392-110 red convergence IC is bad...normal procedure===
    1) pull chassis   2) replace both Stk's for reliable repair
    3)re-assemble  4) re-align convergence
    If you hire a technician, 400.00 is ave. price.
    Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
    Toshiba 50H81 50" Rear Projection Television Logo
    200 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
