Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
No gas is getting into the carburator. If a put gas direct into it the lawnmower starts.
  • Craftsman Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Sep 11, 2010
Why does my lawnmower die after starting?
What does cleaned it "somewhat" mean? You need to rebuild it, not just clean it. Buy the proper kit for it and rebuild it.and make the proper adjustments to it after you put it back together. If you're not sure. When you take it apart slowly turn in the adjusting screws and count the number of turns until it bottoms out, then reset it to that number after you rebuild it, that should get you close enough for it to run properly.
Aug 11, 2014 | Garden
Lawnmower starts and dies... where is the main jet for the carb?
try cleaning the air filter, then a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season.
Aug 27, 2010 | Poulan "Poulan" Push Mower
Lawnmower sat up for a season would not crank replaced sparkplugs air filter fuel filter hose fuel pump is pumping gas to carburator but still will not start unless you pour some gas into the carburator or...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
Aug 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
Murray 21 inch 3.75 lawnmower. Not starting.
buy a ethanol based spray called start ya bastard. spray in the carburator and then pull the cord. 9 out of ten it will start
Mar 14, 2010 | Garden
Cant start craftsman riding lawnmower
try charging the battery for 4 hours
check the oil, spark plugs,
do you have to sit on the seat to start it?
Oct 31, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Scott's Lawnmower/after using all the gas in the carburator...
Check the fuel inlet, and make sure that the 'feed' is ok.
You might want to change/flush the fuel filter.
Have fun ;)
If problems still persist, you know where to come.
Jul 31, 2009 | Garden
Lawnmower won't start
your carburator is dirty inside.the needle and seat need to be replaced.the needle holds back the gas when it's not needed.hope this helped,just let me know................................
Jun 06, 2009 | Garden
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
282 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
