Question about Sharp AR-275 Copier
Paper jams at the fusing unit on my Sharp AR 275
    Sergeant:
    Champion:
  • Sharp Expert
  • 345 Answers
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Posted on Oct 15, 2010
PLEASE HOW DO I CLEAR ERROR CODE h5 ON sharp AR 5620v?
Check the jam paper remaining in the fusing unit, check the p out sensor harness and check the installation of the fusing unit. Use sim 14 to clear self dialogue display
Dec 10, 2015 | Sharp Office Equipment & Supplies
My sharp copier is having paperjam i have all tray still it still occur
OK!! this is a bit tricky because you didn't specify the jam location or locations and I am not really sure of what you actually meant regarding the trays....Try this:
If the paper is jamming in the trays - meaning it might not feed at all...when removing this please make sure there is no paper inside the paper pick unit or assembly area.
Under the Manual Feed Guide there is an access ( a small door ) where most operators overlook, open this and see if there is a paper jam in place.
For the rest of the machine area, the small screen on the operational panel should indicate where the jam is.
CAUTION: Call a qualified tech rep to help you as certain areas of the machine are extremely hot and also to prevent accidents.
Feb 22, 2011 | Sharp AR-275 Copier
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
I keep getting paper jam on my copier, tried cleaning the tray and feeder compartment but still the jams and squeezing of paper. what should i do pls
Try it from another paper tray and see it if still jams. IF it goes through, your first tray needs a roller cleaning or new rollers. Is it jamming out of the cassette or up into the fuser?
Feb 11, 2010 | Sharp AR-275 Copier
I have error code h5-01 on my copier ar 275. how do i fix it?
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation
Clear the trouble with SIM 14.
To clear the trouble with SIM 14, enter the SIMULATION mode.
Enter # INTERRUPT C INTERRUPT, then hit 14 and the START key. Then hit either OK or START again.
Exit the SIM mode easiest by turning the machine off and back on again.
Sep 25, 2009 | Sharp AR-275 Copier
Call for service
Cause The fusing JAM is not completely
Fusing unit installation failure
Check and remedy:
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
Sharp-275 Not a simple paper jam
This sounds like you may have a bad jam detect sensor, there is a sensor on the exit end of the fuser on the right and the flag for this is located in the middle of the exit guide on the fuser this gives us most of those types of jams.
Hope that helps...
Jun 16, 2008 | Sharp AR-275 Copier
Sharp AR-275 Copier Logo
123 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
