Question about Rancilio Silvia Espresso Machine
I have a (nearly) 3 year old Silvia. I have made approx. 10 espresso drinks per week during that period - with no problem. All of a sudden, with group head loaded with a normal amount of Starbucks espresso (pre) ground coffee, I get barely a trickle of espresso. Without coffee in grouphead, it runs fine.......but then I never tried it without coffee in the grouphead until I had this problem. I used "dip it" 4 times - thinking scale buildup was problem. I cleaned the dispersion screen (soaked in dip-it over night & brushed) and ran 4 or 5 cups of water through the empty (no coffee) group head. Nothing works. Any pearls of wisdom?
  • 1,089 Answers
Your 3 way valve is stuck. Its the panel behind the brew head. Slides to the right only.
Posted on Sep 11, 2010
  • bansheracer Sep 11, 2010
    Sorry I didn't read it all. you could also have a bad pump or a overpressure valve the is releasing water back into the water tank. Check the return hose for the later.
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
Hi. I have a Rancilio Silvia Espresso machine which has a light that cycles on much more frequently than normal when I am using the Steam option. I have injured the machine somehow, I'm afraid. I was using...
First of all, your machine is not safe to use so do not use it. A thermostat maybe have shorted out, a wire may have grounded, who knows. Pull the top off and determine where and what has burned out. It should be quite visible.
Feb 09, 2011 | Rancilio Silvia Espresso Machine
I have a Silvia which is about 6 years old. Over the last few weeks, when I am brewing coffee, some water leaks around the portafilter. The portafilter is well seated and properly tamped. How do I approach...
Have you ever changed the brwe head gasket? It should be changed yearly at least. They get hard from the heat and won't seal. They should be soft to make a good seal. You can change it your self. I have left post on changing gaskets. Look for Silvia solutions.
Nov 14, 2010 | Rancilio Silvia Espresso Machine
I have my Silvia for 3 years and for the last couple week, it gives me espresso watery with no crema. I havent changed anything for the last 3 years. Please help!
It definitely needs preventive maintenance once a year. There could be a couple of issues causing watery espresso. You could have a clogged shower screen or cracked porta-filter basket. They bypass valve from the pump could be leaking causing low pressure (check this by pulling a shot and seeing if water continually flows back into the tank via one of the water hoses).
Mike mikey@espressomachineexperts.com
Oct 15, 2010 | Rancilio Silvia Espresso Machine
Silvia leaking water
Hi
The solenoid valve needs back flushing the correct way with a espresso machine detergent like Cafiza, or Joe Glo. Place a 1/2 teaspoon in a blind basket. (don't come with Silvia). Place blind basket in portafilter and brew like making espresso, but run pump for no more than 5 to 10 seconds or until the pump starts to change tone (slow down). Stop the pump when either of these things happen or Silvia can be damaged. Repeat the pump 5 to 10 times leaving a 1 minute wait between cycles, or the suds comming out the 3 way valve turns pure white, with no coffee stains in the foam. Remove the portafilter and rinse then reinsert and repeat the cycles to rinse the internals. This should take care of the problem. If not you may have to replace the 3 way.
Nov 12, 2009 | Rancilio Silvia Espresso Machine
Leaking between base stand and body
You are correct. There might be something keeping the solenoid from closing. Yes you husband should be able to fix it. Have him clean out the solenoid.
Sep 28, 2009 | Rancilio Silvia Espresso Machine
No water from group head, Roncilio silvia
Hi Sounds like you have a stuck 3 way valve. Its behind the panel in the front. The panel slides to the right when the screw are out.
Jun 26, 2009 | Rancilio Silvia Espresso Machine
Noisy during heating cycle
element is litlle bit bad.you need change element .
Nov 02, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
108 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
