Question about Xerox Phaser 8500/DN Printer
Waste tray is not being filled with left over wax. Printer is smearing ink.
  • thecenterfor Sep 10, 2010
    It is a Phaser 8560MFP.
    The printer is a Phaser 8560MFP! Not a 8500/DN
    President:
  • 2,777 Answers
How long has this been happening? How old is the unit? Please verify the make / model for me and I can help you further, is it a 8500/DN Xerox?
Thanks
Tim
Posted on Sep 11, 2010
    Genius:
  • 1,478 Answers
There are a few possible could cause this. First, the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time. In a black-and-white laser printer, the solution is to replace the toner cartridge.
Take care.
Posted on Sep 10, 2010
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
Ink tray full what to do
'ink tray full' - no references found on the following site:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150_refurbished#ServiceAndSupport
Usually on a laser printer (which this is not) there is a waste toner bottle that fills up with waste toner. But, I am unaware of it being this way on your mp150.
p.108 of the user manual says that the waste ink absorber must be replaced if you get an error 1700 with a Mac.
Press 'OK' to continue printing until the waste ink absorber is really saturated or filled, and the printer will not print until it is replaced.
Warning: I didn't see the part listed, though, so you may be looking at another printer to replace this one if you can't resolve the issue.
Good luck on this repair.
Jul 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Iwant to clean out or change waste ink pad on epson r265 printer. have just used cotten buds to soak up waste ink to fix flashing lights. but i think only a temp. solution
Photo walk through here shows how to access waste pads
http://www.inkrepublic.com/KnowledgeBase/R260WasteInk.asp?C=0
Also shows how to replace with a bottle to collect waste ink
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
Need to clean waste ink pad on epson r265 printer
You need to remove the Paper support tray, printer cover front cover usb housing and right and left housing then remove the waste ink tray inside the tray you will find about 12 pads that need taking out you can just replace them with new ones or wash and dry them and re-install them the latter is very messy then refitt everything and then you will need the service utility to restet the printer If you need further help email me at drummerboy36uK@yahoo.com or try me on msn messenger using thedrummerboy53@hotmail.com
Waste tray message will not leave display panel even though tray is empty
You will most likely have to remove ( looking at the machine from the front) left cover and clean out some spilled ink from the waste tray sensor.
You have to remove one screw from the back top of the cover, then the top front of the cover. Lift up and out on the cover to release the tabs and pop the cover off. Then have someone slide the waste tray in and out so you can locate where that tray seats into the sensor.
Most of the time, some ink spills into that area in the back of the waste tray, and blocks it from sliding all the way in.
Jan 05, 2010 | Xerox Phaser 8500/DN Printer
Printer error 07,007.40:80035
Xerox 2424 or 8400 series 07,007.40/49 is a process motor sequence error often caused by the printhead leaking wax on to the pivot shaft and bearing block mounted on the left side of the printhead unit, this stops the printhead tilting. Check for leaking wax around the silver block on the side of the printhead or around the waste tray, if wax gets into the tilt gear at the back of the waste tray slot, this is the error it shows.
Oct 24, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox Phaser 8500 Error 09,005.40:100473
You don't have to take all the printer apart just the ink loader. Which is held mostly by the side covers. Get a flat head and break down the peaces left over on the cyan ink and flip upside down the ink loader and that should make it work again with no problem.
Jul 30, 2009 | Xerox Phaser 8500/DN Printer
Power button and tear drop button contstantlt flashing
This usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type, then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is not too difficult once someone explains how to get the case apart!
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
Blurry Printing
Quite possibly, your Wave Amp board has failed. If so, it is more cost effective to purchase a new printer than to repair yours unless you can find used parts.
Currently, Xerox is offering a trade-up rebate on new solid ink printers.
Mar 26, 2009 | Xerox Phaser 8550DT Thermal Printer
Both the power light and maintenance lights are blinking.
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom left corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the system tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 10, 2009 | Epson Stylus C42UX InkJet Printer
Xerox Phaser  8500/DN Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
