Question about Apple iPod touch
My apple displays on the screen CONNECT TO ITUNES.how can i solve this problem pleaseI?it also displays IPHONE deactivated.what should i do?
  • 395 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} goto the website http://www.felixbruns.de/iPod/firmware/
and download the selected firmware for the ipod touch model you have. if your unsure if the model / type you can goto http://www.felixbruns.de/iPod/firmware/#
and type in the last 3 numbers of your serial number to find out
if you want to downgrade or upgrade, choose the firmware you want to downgrade to, then go to itunes and shift-click on restore and choose the firmware you want to change to. this will restore your ipod touch
Posted on Sep 11, 2010
My screen is stuck on plug into the itunes screen
Probably something went wrong, and your iPhone itself sees that too. That's why your iPhone asks to connect it to your PC or Mac with iTunes installed.
-Start iTunes on your PC or Mac
-Connect your iPhone to the PC or Mac
-Probably iTunes will advise to recover your iPhone.
>>If you didn't make regular backups of your data you probably will lose the data that's on your iPhone.<<
-Wait until the recovery procedure is done and see if your iPhone works again.
What if iTunes doesn't recognize your iPhone anymore in iTunes?
Thy a "soft reset' by pressing the ON/OFF button on top of your iPhone and the round menu button underneath your screen simultaneously until your iPhone reboots. Check if your iPhone connects to iTunes and try the recovery.
I hope this will help you solving your problem.
Feb 10, 2014 | Apple iPhone Smartphone
Cant update my iphone 4 (model mc609ll )
Perform a recovery-mode restoreIf your iPhone, iPad, or iPod touch is already showing the "Connect to iTunes" screen, please go to step 5.
  1. Connect your USB cable to your computer but not to the iPhone, iPad, or iPod touch until step 3.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button down, connect the USB cable to the iPhone, iPad, or iPod touch. The device should turn on.
  4. Continue holding the Home button until you see the Connect to iTunes screen. When this screen appears, you can release the Home button:
    Note:
    If the image of a battery appears, let the device charge for at least ten minutes to ensure that the battery has some charge, and then start with step 2 again. If you don't see the Connect to iTunes screen, try these steps 1 through 4 again.
  5. iTunes should automatically open and display the following message:
    [img alt="Alert text: "iTunes has detected an iPhone in recovery mode..."" width="520" height="241" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1808/HT1808--recovery_alert-002-en.png" data-hires="true">
    "iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes."
    If iTunes not open after two minutes, please open iTunes yourself.
  6. Use iTunes to restore the device.
Sep 21, 2013 | Apple iPhone 4 Black Smartphone
My screen on my 3gs displays "iphone is disabled" connect to itunes, but i can slide the bar over to the emergency call screen any ideas please?
You have to connect the phone to the computer, open itunes, and click the iphone on the left pane, then click restore. this will erase all your data including apps.
Feb 22, 2011 | Apple iPhone 3G
When i restart my iphone 3g after delete some installed apps it hung up to apple logo and i tried to reset it using pressing home and sleep buttons for ten second and the screen flashed white without any...
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 27, 2010 | Apple iPhone 3G
Iphone wont turn on
Dec 26, 2010 | Apple iPhone Smartphone
My iphone is not recognized and cannot be activated for service
You need to restore the iphone as a new iphone
Dec 26, 2010 | Apple iPhone 3G
Iphone will not get pass apple logo even after i reset it several times
hi you need to restore your iphone as new...hope this helps!
Dec 25, 2010 | Apple iPhone Smartphone
The sensors on the screen of i phone 3gs cant feel anything
check with apple to see if your still in your warrenty and they'll fix it for you for free..you could try restoring your iphone first but it may not work, ive left the steps below for you to try restoring it, hope this helps!
Dec 25, 2010 | Apple iPhone 3G
Iphone problem "please connect to Itunes"
restore to the latest firmware (1.1.3) and try again
Dec 25, 2007 | Apple iPhone Smartphone
Apple iPod touch Logo
85 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
