Question about Dryers
I need to get inside the dryer and check it out. how do i get in? top?front?back?
  • Dryers Master
  • 7,482 Answers
LWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor or belt or other things and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Sep 11, 2010
How do i take off top of dryer to change belt
Unplug the dryer! My dryer top is hinged in the back, so I just gently pry up the front of the top after unscrewing the lint trap. Then there are two screws near the top of the front panel holding the front panel to the sides. Remove screws, then the front panel lifts up. The drum will drop down. You can now remove the drum since the belt is broken. Check the back rollers, clean the motor, clean out the inside of frame, replace the belt - making sure it is fed through the idler properly, install the drum- working the belt around the drum, making sure the belt is not twisted and in the correct position on the drum. Reinstall the front panel, making sure the drum is seated properly on the back panel and on the front panel, now you can lower the top and have at it. Your dryer may be alittle bit different but a dryer is still a dryer.
Nov 12, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How to remove dryer cover?
Instructions
    • Open the dryer door and locate the screws underneath the front lip of the dryer top. Unfasten the screws with a screwdriver and set them out of the way.
    • Flip the dryer top back so it is setting on the rear hinges. Locate the screws on the inside of the front panel near the top of the dryer.
    • Unfasten the screws on the inside of the front panel with a screwdriver and set them in a safe place. Lift the front panel up so it comes off the metal clips at the base of the dryer in the front.
    • Unplug the two-pronged electrical wiring connector from the back of the front panel by hand. Set the front panel of the Amana dryer cabinet out of the way.
Jul 02, 2012 | Amana ALE230RAW Electric Dryer
I have a ge profile 2006 front loader dryer that is making an awful squeaking noise!!
It will be your back bearing or front glider pads that are bad you will need a qualified service technician to come out to repair it unless its eating thru the metal on the inside then its not worth fixing sorry for the trouble and good luck. You can check the front pads by open the dryer door looking on the inside of the dryer towards the top front and see if it is resting on the plastic clip or metal that will tell you if its the fron or back.
Jan 06, 2011 | Dryers
CAN'T GET BACK OFF DRYER TO SEE IF BELT NEEDS CHANGED. DO YOU GET IN THIS MODEL FROM FRONT, BACK OR SIDE?
Access from front. Open door and remove two vertical screws in upper corners of door housing. Lift top slightly and pull forward to remove top. Remove two screws in top corners inside front to remove Front panel.
Nov 15, 2010 | GE DBXR463ED Electric Dryer
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
GE Dryer Model DWSR483EA1WW squeaky noises
Un-plug dryer. Remove screws from front panel into dryer top. (just inside the door, at the top of the opening) Swing top up and remove screw near top of front panel on each side. Tilt front panel forward and lift off, set to the side. (leave wires attatched) Pull drum ahead about 4 inches. Do not remove belt. (it's a little tough to get the drum past the sides of the dryer) Remove the old rear drum bearing and replace it. If I remember correctly, it is a part number WE3X37. Replace drum. Check the front drum support slides on the front panel. They should be about 1/8 inch thick. If the rear bearing was squeaking, they may need replacing also. Finish re-assembly, plug back in and test.
Oct 18, 2009 | Dryers
Kenmore dryer won't turn, i got the back off what now?
Hi. you cant get at the belt from the back. its from the front . remove the screen . 2 screws on the top. remove 2 clips on the front between top &front . pry the top up. 2 screws inside the front remove. belt is there replace. thanks the appliance doc
Aug 25, 2008 | Kenmore 73952 Gas Dryer
Dryer
your belt or idler arm has fail,you need to remove to lint filter screw then the top,pull the top froward then up,remove to front panel screws on top,remove front panel,look at the top of tub and see of you see the belt,if not your belt has failed,pull the tub out the front ,also check the ldler arm on the bottom right,make sure the wheel is spinning free,get the model number off dryer,most times it's inside the dryer door or on the top back panel,get the new part from the appliance store and follow the direction that come with it,hope this helps
Jun 02, 2008 | Kenmore 63942 Dryer
I need to replace the belt in my ge dryer. how do i get the back off to get to the inside. we have unscrewed every screw and it doesn't seem to want to come off.
whirl pool and most other manufacturesdryers are front serviceable for belts depending on dryer top pops up (2 srews under filter on whirpool top filter dryers )2 front clips push those in top lifts ..2 screws on inside front panle take out front lifts off
Apr 26, 2008 | Dryers
DRYER HEATS ,BUT DOESN'T TURN
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
Top Dryers Experts
