Question about Heath Zenith Electrical Supplies
I need to know what settings to put my motion light on -- it stays on all night
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
Light stays on on motion security light
If you click the power to it on and off and on again, they stay in permanently.
On a fixed installation, the sensitivity is set too high. Or it is faulty.
Oct 09, 2016 | Home Security
My Defiant LED outdoor white Blade Motion Security stays on all night
You may need to set the parameters once chosen which means you need to hold the set button in for at least three seconds once you have selected your choices.i usually set new up in the house and then check the duration of the light before installing in situ.
Jan 28, 2015 | OUTDOOR Home Security
I have set all the switches to the left TEST, Low sensitivity and Dual brite OFF and this light stays on all night??
putting the switches on test bypasses all the sensors leaving the light on all the time the test selection is only there to see if the light is working
Jan 15, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
Cooper ms34w wont turn off stays on night an day without movment
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Mar 25, 2014 | Cooper Lighting Flood Lights. 180 Degree...
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
When i flip the switch on the light stays all night it doesnt turn off it was working fine i dont know what happen an i lost manual so can u please help me
Clean the light motion sesor plate under the light bulb.It dirty and it cover with dirts and moister probally that,why it on all the times.
Oct 16, 2010 | Heath Zenith 270 Degree Replacement Motion...
I would like to rewire a solar security light (motion activated) to stay on at dark. Brand westinghouse
The light will only stay on as long as the battery lasts. My guess is that will not last all night. What you can do is buy a light sensor switch (or even a light sensor socket adaptor is available to save you from having to wire it in) to keep a light on during the night. You can use a CFL or even an LED lamp to save electricity, but it is unlikely that a solar-charged cell will power even one of thes all night long.
Nov 16, 2009 | Solar Motion Security Light Conversion...
Dual Brite sensor lighting. Lights will not stay on even after human motion is in place sight of sensor during evening hours. I have the switches on dusk to dawn and the on-time switch is set to 20...
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Jul 12, 2009 | Electronics - Others
Electrical Supplies Logo
42 people viewed this question
Top Heath Zenith Electrical Supplies Experts
lakeareaserv
Gene Haynes
George Balanchine
George Balanchine
Level 1 Expert
Are you a Heath Zenith Electrical Supply Expert? Answer questions, earn points and help others
