Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Although it starts up as usual my wd hd is not visible on my computer and doesnt turn off? Any suggestions other than throw it away, as I would like to retrieve whats on there.
  • Western Digital Master
  • 27,725 Answers
Replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 11, 2010
Why my tv won't stay on ?
Check your input source. TV is coming on and switching to an input where the source is not on
Sep 26, 2014 | Mitsubishi WD-73737 73 in. HD-Ready TV
My dishwasher doesnt drain away
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 01, 2011 | Dishwashers
I have a WD Media player and a WD 1tb Hard disk they problem I have with them is I copy Movies to the hard disk but they do not show when I use the Media Player Can you suggest how I can view them Ian...
The movies have to be in the format that the media player can handle. If not, then they will not be visible, leave aside viewing them. You must download movies that are the same format as the player, eg, .mov or .wmv or whatever.
Nov 16, 2009 | Western Digital TV HD Media Player USB...
My computer restarts recognaizing WD external hard drive!
I suggest you check the power management on the device. You can right-click the disk in the Device Manager and see if it is allowed to be powered off, or you can check the power settings in the control panel.
Most likely it is turned off, and when it resumes, the computer somehow thinks it was not plugged before.
Jules
Apr 19, 2009 | Western Digital Passport WDXML800UE...
I have a Western Digital external HD which I use for backing up our family computers. This last weekend it has decided to fail. The HD connects to my computer via USB but when I do the computer gives no...
You can check the voltage coming from the power supply to the drive and confirm that it is correct and you can also switch USB cables and ports but likly , you could be correct. The HD may have just failed.
Dec 14, 2008 | Computers & Internet
My internal hd sata seagate 1 terra is not recognizible any more
Domez,
Try Testdisk to see if it can restore the boot sector.
Chappo07
Sep 15, 2017 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Screen Turns Pink-Mitsubishi 57'' Wd-Y57
since dlps use a color wheel to make the color the color wheel may be going out. get it serviced
Nov 15, 2008 | Mitsubishi WD-Y57 57" Projection HDTV
Wd external hd
not possible. i suggest 24/7 antivirus monitoring.
Feb 15, 2008 | Western Digital 320GB MyBook External USB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
35 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
