Question about Whirlpool Dishwashers
WMy whirlpool gu2400xtps6 has standing water.drain hose seems to be clear.can i check the impeller from inside the washer? any illistrations?
  • Whirlpool Master
  • 3,247 Answers
There may be oher reasons for the water standing in. The drain hose may be clear but does the pump actually run during the drain cycle? Do you hear the sound? Have you checkd the outlet under the sink is not blocked or if you have insikerator has it been emptied.
The parts assembly diagrams for you model can be viewed at this location.
Hope this helps.
Posted on Sep 10, 2010
AWM5145/2
check if water pump dont release water properly..u can see that in the end of drain hose ..fill the washer w/ water then set it to spin after that look the hose if the water flow properly..
Mar 08, 2014 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool cabrio washer f 33 error code
Whirlpool Cabrio strange fix. This thing acted strange, If I went to drain spin it would run trying to work but I could not cancel this function and would have to unplug to reset the machine I had the F 33 fault code, I pulled the drum out and found about $2.00 worth of change. Then I put the washer on it's face and removed the back panel then disconnected the hose to the pump and spun the impeller to make sure no blockage was present. lt was clear so I reassembled the washer and washed one load of clothes and had the same problem occur. Washer would not drain or spin. Went back to work on the washer and in the process of moving it out from the wall I disconnected a 4' hose that I hadn't disconnected the first time that I have running to the drain from the drain hose on the washer, at this point I noticed water coming out of the washer drain hose. To make a long story short my 4' drain hose addition had a ripped up sock plugging the hose. Unbelievably this sock made it through the washer and pump and plugged up the hose. I never thought a sock could make it past the impeller so if your Cabrio is not draining or spinning check the hose past the pump, you may have an easy fix.
May 16, 2013 | Washing Machines
Not pumping out water
I have had the same problems many times with this washer. It is usually something that has made its way into the pump inlet located below the tub. You will need to disconnect the water lines and the power, tip the washer back and access three 8mm screws on the bottom panel located across the front of the bottom panel. You will then see numerous hoses connected with spring clamps. Remove all the spring clamps and disconnect all the hoses. You will have quite a bit of water dump out, but this is normal. Look inside all the hoses to see if there is a blockage. Also feel around inside the openings of a clear plastic container located at the back of the washer. I have found socks jammed inside completely blocking the water flow. In one opening you will see a small white ball...this is normal as it is a check valve and needs to remain in the container to ensure proper operation. If you have not found any blockages in any of the openings, you will need to remove the impeller from the pump motor. As you look at the bottom of your washer, it is located on the right side halfway between the front and the back with two short hoses attached to the plastic container previously mentioned. Remove the two small clips holding the impeller to the motor and you will be able to pull it down. Insert your finger into the opening and ensure the blades inside rotate freely. I have also found a penny stuck inside the impeller in the past that has not allowed the impeller to turn. After removing any obstructions, replace the impeller and reconnect all hoses securely. Hopefully this will fix your drain problems. I have had this washer since 2003 and I have had to follow this procedure nearly once a year. Hope this helps!
Jun 03, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
The washer smells funny. Like mildew or something. No water standing. Seems to drain.
Probably has some standing water in the pump hoses as well as the drain hoses If you do not use the machine often, then some water is left in the drain hoses and upon evaporation it may do what you smell. Pour some bleach in the tub, with water and let stand for 15 min. put it on rinse and let drain and do the smell test again.
Jan 09, 2011 | Whirlpool WTW5300SQ Top Load Washer
Whirlpool washer agitates, but won't drain water
HI, any resistance when turning the impeller in this case will confirm pump failure. these motor should have very slight resistance when manually rotated. the unit will not initiate a full cycle if the pump is defective. replace the pump asap.
Jul 24, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool washer water won't drain out
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
There is standing water in the bottom of my dishwasher.
Check the following.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Mar 19, 2009 | Whirlpool DU930PWS Built-in Dishwasher
Washer will not drain or spin motor making clicking noise
Likely has debris in the filter.
Open the bottom access panel (3 screw on bottom front lip)
open the filter access and be ready for some water spill ,have towels.
clean and check the pump impellers for freedom of movement.
if you still have noise after this you may have to go deeper past the pump and remove the hoses as the debris can be past the pump now.
Or take the machine outside and run water up the pump using a water hose to clear it. be inventive
Oct 26, 2007 | Whirlpool GHW9100L Front Load Washer
Dishwashers Logo
64 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
