Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Tub will not spin unless I manually turn it, then it will take hold and finish spinning. Someone told me it was the clutch. The washer is 8 years old. Is it worth fixing?
  • 905 Answers
If you are able to hear the motor running "normally" while the tub is not spinning, then it likely is the clutch. Leaving it running like this (motor on but tub still) will eventually produce an acrid smell which will confirm the clutch.
If the motor just seems to hum and not spin, then the start capacitor is likely faulted.
Both are reasonably cheap as far as parts go, but clutch replacement can be a chore. Capacitor replacement is very easy. If you are mechanically apt, you can replace the clutch itself.
This washer is definitely worth trying to save (my opinion), but ultimately it is up to how much time you have, how much money you want to put into it vs the cost of a replacement.
Posted on Sep 10, 2010
Machine won't go past "31" in the wash cycle. Does not code anything, just spins a bit, stops, repeats, stays on 31. I've posted two other problems with this machine in the past year. Have replaced a...
HopelessR
You may not want to hear from me again. This person had similar issues related to a Tub Seal and Outer Tub Bearing noise. I worked with him thru on a Outer Tub bearing, Tub Seal and Clutch replacement.
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/17706-neptune-tl-spinning-issue-will-not-proceed.html
“”Okay I will try to say what I have done so far. The washer keeps trying to go thru the spin cycle. It starts spinning & then stops & then starts up again, over & over & never finishes the cycle & doesn't expel the water.
NO codes come up as an issue either. “”
I did a lot of off line work with him via e-mail. I'm going to ping him and see if his machine is still in service.
Do the Quick spin test and see if the wash basket will spin up to 850RPM. Maybe we have some binding with increased Outer Tub Bearing resistance and or Spinner Support bearing resistance.................or it may be time for a plain vanilla $300 machine replacement.
Have you droped the clutch out to see if you have water contamination with the One-Way Roller Clutch bearing and Upper bearing ring. I believe you have a Series 10 machine.
Maybe someone else on the forum may chime in with a handy tip.
Let ya know how the other forum member fix is doing if he responds back to me.
D*ick
Aug 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
Model 2485-2300 Top Load Washer I have to
First, see the Sears Parts site for washer model 110.24852300 which I assume is your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24852300
Whirlpool / Kenmore top load direct drive washers use a clutch to start the Spin Tube which turns the tub.
They also use a Neutral Drain Assembly in the transmission which allows the washer to drain most of the water out before starting the spin.
Two possibilities:
First, See the following for how to remove the cabinet, pump, motor and transmission in order to check the clutch.
You don't have to remove the drum.
Check the clutch for wear as well as the springs. If the clutch is worn or the springs are broken, Sears has a "rebuild kit" for the clutch.
If the clutch is OK, the problem points to the Neutral Drain Assembly in the transmission.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Manually turning the drum apparentlthrows the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Nov 29, 2009 | Kenmore Washing Machines
Kenmore 110.23832100 post rinse cycle spin problems
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23832100
See the Whirlpool service manual for these washers.
Sometime spinning points to a few places.
First, Kenmore top load washers use a motor coupler to transmit power from the motor to the transmission for agitating and spinning. If the coupler is worn or damaged (the prongs on the motor or transmission shafts are broken) the machine may agitate but may not spin.
Second. These washers use a clutch to transmit power to the tub for spinning. If the clutch is worn, it may not be able to transmit all of the power from the transmission.
Third. These washers are whats called Top load, Direct Drive Neutral Drain. This means that when the washer goes into spin mode, the "neutral drain assembly" has a built in mechanical timer that allows most of the water to drain and then begins the spin cycle.
If the cams in the neutral drain assembly are broken or, as we found onours, a spring on one of the cams is broken, the machine won't spinwithout help.
Forth: These washers use a spin tube, driven by the clutch and connected to the tub with a "basket drive block" If the tabs on top of the spin tube have broken off or aren't inside the slots in the drive block, the tub may not spin.
All of the diagnostics start with pulling the cabinet.
See the following:
With the transmission out you have access to the motor coupler and clutch. Check both before proceeding.
If the motor coupler and clutch look OK, I'd pull the tub and spin tube and check the tabs on the spin tube and drive block.
If all else appears OK, the problem points to the neutral drain assembly.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
Oct 27, 2009 | Kenmore 24032\24036 Top Load Washer
UC code on my Maytag Neptune Washer FAV6800WW
HI. this uc code represents a no spin state of the unit. this is caused by a faulty Motor control assembly. you will need to replace the Motor control assembly. this will fix this issue and, restore the normal actions of the unit.
This Motor control assembly will cost about $219.00.
Jun 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Machine washes but ont the spins it wont kick the clutch in
yep the clutch is going out you are lucky it will spin at all
Jan 13, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washer wont spin
if the coupler and clutch are ok and you can hear the motor functioning, then it appears that your transmission is bad.most of the time you will see that in the days/weeks leading up to this that your cloths were more wet than usual when you took them out of the machine. Check your owners manual for warranty information. Some machines had a 5 year warranty on the transmission or gear case as whirlpool likes to call it.
Dec 29, 2008 | Roper RAS8445KQ Top Load Washer
MY CLOTHES SPIN BUT STILL ARE VERY WET SOMEONE TOLD ME IT WAS THE CLUTCH DO YOU THINK THIS IS THE PROBLEM
More than likely it is the clutch. I would think if the tub is very loaded it just barely will get started spinning. However when the tub is empty to spins like crazy. If this is the case then it is the clutch.
Dec 08, 2008 | Kenmore 24902 Top Load Washer
Fisher paykel won't finish spin cycle
To remove the tub you need to remove the spin motor magnets and stator, then using a tube soket undo the tub nut and it will come out. (not EASY JOB)
Sep 17, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
