Tengo un ratón Gigaware id: El Problema es 062n530 Que bien trabaja 20 minutos y despues sí Queda Prendido El lazer y ya no Funciona El ratón y lo Apago le quito Las baterias y Sigue Con El Mismo Problema Que solucion me dan . gracias
    President:
  • 8,637 Answers
Copy this site and paste it in your web browser address bar and hit your enter key.
http://www.radioshack.com/uc/index.jsp?help=yes&page=software
It has the Description and Model number.
Then download the driver for your camera and install it as below.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Posted on Sep 13, 2010
Hola le acabo de cambiar los empaque a mi 300 crysler y cuando ya avía terminado le quice echar agua y empezó a liquiar agua x un ojito que está junto al termostato
Se me hace que el empaque se movio cuando tratatse de hacer el reparo. Ponle un poquito de empaque liquido en un lado de el empaque, ponlo y deja unos minutos (como 10 minutos) y pon las partes juntas y apriete los tornillos; pero no muy apretados. Deja como 20 minutos y aprietalos bien; al torque aprobado para la parte. Ten cudado de poner el termostato al lado que se debe poner. Perdon de mi deletreado, tengo mucho de no escribir en mi idoma.
Nov 22, 2014 | 2006 Chrysler 300
Hola, mi problema con mi pc es el siguiente.. tengo una toshiba satelite A70/75. y despues de unos minutos de estar funcionando bien repentinamente se apaga, vuelvo a encenderla y despues de unos minutos...
Desmonta y vuelve a colocar la bater?a, verifica que el cargador est? bien conectado y encendido, usualmente tiene una luz en la caja. Mantenlo conectado.
Se apaga cuando no se esta usando solamente? Comprueba las opciones de administracion de energ?a (power options) en el panel de control
Si el problema persiste y las luces de la computadora se apagan por completo puede ser el ventilador interno, se escucha algun ruido? Se sobrecalienta?
Apr 05, 2011 | Toshiba Satellite A70 A75 M35 Series...
No funciona solo aparece ecipse y es todo
A mí me pasa lo mismo y lamentablemente nadie aporta una solución, el mío (Eclipse 180 8GB)se ha quedado trabado en la pantalla azul de inicio con el logo "Eclipse" y no sé que hacer. Un tipo en las respuestas en idioma inglés dice que llamó al número de atención al cliente y le dijeron que dejara que la batería descargara por completo y luego presionara por unos 30 segundos el botón "Play" (me imagino que es el botón del centro, supuestamente es la manera de resetear el player) antes de conectar el USB al PC. No sé si funciona. Mi problema empezó por una canción que no tocaba bien y reinicié el aparato, y puse de nuevo la misma canción y luego se puso el logo azul en la pantalla y éste no se quitaba a menos de mover el switch a OFF, lo pase nuevamente a ON para que descargara por completo, pero ya no lo reconoce la PC y pide drivers, se queda congelado en el logo, ni carga, ni nada.
He visto que muchas personas tienen el mismo problema y todavía no aparece ninguna solución, tú post es el primero que leo en español. Dicen que será un problema de firmware, pero no venía con un CD de drivers o una herramienta para estos casos, la empresa Mach Speed parece que todavía no tiene una página de soporte implementada para este modelo "Eclipse", también no sé como destaparlo, pues la tapa es una sola pieza. Si sabes como solucionar tu problema, házmelo saber por este medio. Talvez es de esperar, porque el firmware que tiene mi player era de septiembre del año pasado y lo compré en noviembre, el precio es bajo, pero no es posible que nos tomen el pelo de esta manera.
Feb 10, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
Hola buenos dias: En mi ordenador, tengo una placa gigabyte GA-8S648, y desde hace una semana me aparece el siguiente mensaje al encender el ordenador: "Scanning Bios Image in Hard Drive" Le llevé...
Buenas tardes, si tu computador esta mostrando ese error es por que no logra encontrar el bios. si sabes el bios es el software que hace posible que hardware y software se comuniquen el bios funciona a nivel de i/o para poder inicializar cada uno de los componetes del computador, sin el, son solo piezas separadas;lamentablemete tu placa no tiene un back up rom y si ya lo reseteaste y limpiaste el cmos (removiendo la bateria cmos)lo cual supongo ya hiciste no queda mas que cambiar la motherboard.
Aug 31, 2010 | Gigabyte GA-8S648FX Motherboard
Imac g5 linea blanca vertical en la parte derecha
éstos son algunos procedimientos que se pueden tratar de resolver este problema con la línea blanca de la pantalla. Pero, por favor tenga en cuenta: si estos 2 procedimientos no ayudan, te recomendaría tener en tu Mac en el servicio de Apple en un centro de servicio autorizado
éstos son algunos pasos que usted puede tratar de resolver el problema:
Opción # 1
-PRAM reset -
• En primer lugar, sostiene en su botón de encendido durante aproximadamente 10 segundos para hacer una parada difícil, si no se ha cumplido ya su Mac apagado.
• Una vez que tu Mac está apagado, usted tendrá que realizar lo que se denomina un restablecimiento PRAM (RAM de parámetros)
• Busque las siguientes teclas en el teclado: Comando, Opción, P y R. Es necesario mantener estos teclas simultáneamente.
• Encienda el ordenador.
• Mantenga pulsado el Comando + Opción + P-R llaves. Debe pulsar esta combinación de teclas antes de la pantalla gris.
• Ahora, presionando las teclas hasta que el equipo se reinicia y se oye el sonido de inicio por tercera vez.
• Suelta las teclas y permitir que el MacBook a poner en marcha.
Opción # 2
-Restablecer la PMU -
El administrador de energía es un circuito integrado (chip de ordenador) que suele ser en la placa lógica de su ordenador Mac.
Es responsable de la gestión de energía de la computadora. Controla la retroiluminación, giro del disco duro, el sueño y la activación, algunos aspectos de la carga, control de trackpad y algunas entradas y salidas en relación con el reposo del ordenador.
• Si el ordenador está encendido, apágalo.
• Desconecte todas las conexiones de entrar en el Mac, excepto para el cable de alimentación.
• Una vez que todas las conexiones se han desconectado, quite el cable de alimentación de la Mac.
• Espere 20 segundos.
• Vuelva a conectar el teclado, el ratón y el cable de alimentación en el equipo.
• Presione el botón de encendido para reiniciar el equipo Mac.
Espero que esto haya ayudado a resolver el problema de la línea blanca.
Recuerdos,
-Mactechtrainer
Jan 29, 2010 | Apple iMac G4 Desktop
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
Oct 03, 2009 | 1993 Isuzu Amigo
Como puedo arreglar el audio de mi compuntadora
mi pc es ACER ASPIRE T160, no puedo escuchar el sonido, el problema es desde el comienzo no da sonido ni al prender
Sep 05, 2009 | ZT Group CISNET A7022 PC Desktop
COMO BAJO EL PROGRAMA DEL DRIVE DE VIDEO Y SONIDO A MI PC
Si tu instalación de Windows es reciente, es muy común que tu sistema de audio no haya sido detectado y habilitado inicialmente. Pero, si usas Actualizar Windows, la segunda o tercera ocasión verás que Windows detectó la falta del controlador de audio en el sistema,
y lo instalará automáticamente.
Si este no es el caso, entonces necesitas usar el CD que vino con el tablero, y si buscas en su contenido encontrarás un directorio llamado "Drivers" o algo parecido, o bajo el nombre del fabricante del aparato de audio.
Si logras encontrarlo, entonces ve al Panel de Control y corre el Device Manager (no sé cómo lo llama en español), que es el que despliega la información acerca de los componentes internos y externos de tu PC.
Muy probablemente encontrarás al menos uno o dos que tendrán un ícono amarillo, o rojo, indicando que el aparato en cuestión no está configurado y por supuesto, no funciona.
Si este es el caso con tu tarjeta de audio, entonces haz un click con el botón derecho del ratón sobre el aparato y selecciona "Desinstalar" (o como se diga en español). Cierra todos los programas y recicla tu PC normalmente, usando "Inicio->Reiniciar el sistema".
Cuando Windows arranca otra vez, espera unos minutos. Verás mensajes de que Windows ha detectado nuevos componentes, y que está instalando sus controladores. Un par de minutos después, todo estará de vuelta a la normalidad.
Si en vez de esto el mensaje dice que no se pudo instalar, o no se encontró, entonces busca, dentro del Panel de Control el ícono para añadir componentes. Aparecerá una ventana donde los nuevos componentes se detectarán automáticamente, pero nuevamente aparecerá el mismo mensaje de que no se encontró el controlador. Pero, te da la opción de buscar en un lugar específico de tu sistema por el controlador.
Aquí entonces busca la letra de tu aparato de CD/DVD, que contiene el disco que vino con el tablero, y seleccionas el directorio anterior. Luego, presiona OK/Continúe tantas veces como sea necesario.
En el último de los casos, dirígete a la página del fabricante de tu tablero, y anda a la página de apoyo al cliente, en la página de Descargas busca el controlador, basado en el modelo del tablero en cuestión.
¡Buena suerte!
Jul 17, 2009 | Asrock 775VM8 Motherboard
Como recoger etiquetas de 40 cm de largo
Entiendo que la impresora tiene cortador y salen cortadas de una en una, ¿cierto? Si es el caso, hay un apilador de etiquetas cortadas que puede funcionar en esta impresora, aunque es mucho mas barato hacer un cajetín un poco mas grande que las etiquetas y poner tres topes, 2 laterales y uno en la parte mas alejada de la impresora, con un poco de inclinación en el cajetín. Esta solución la tengo instalada en varios clientes y funciona razonablemente bien.
Saludos
Apr 07, 2009 | Toshiba TEC B-852 Label Printer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
