Question about Sharp EL-1750PIII Calculator
My calculator will only print symbols ... for instance when i hit the c/ce key it prints =% ...any idea how to make it print what is on the screen... i reset it and checked the manual to make sure all of the switches are set correctly
5 Suggested Answers
  • 329 Answers
SOURCE: errors??
Sounds like the printwheels are out of time. Sorta of major repairs. gears on side of printer have to be lined up in proper areas. there are small black arrows on the gears. Best bet is look at a working machine and try to line up. Machine may not be worth the time unless you jsut want to try it. Sharp uses the same printers in many different models.
Posted on Jun 24, 2008
  • 16 Answers
SOURCE: CALCULATOR MIS-FUNCTION .
unfortunately the printer is out of time or the selector pawls got bent. would be cheaper to buy a new one than fix this.
Posted on Apr 28, 2010
SOURCE: setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Posted on Aug 03, 2010
alpug
  • 1961 Answers
SOURCE: When I turn the calculator
there is an mechanical error on your paper feed it could be the printer head or the roller better check for any broken gears belts or sensor...or the paper is not properly place..good luck pls rate my help by clicking the thumbs up button..
Posted on Sep 09, 2010
Ibico 1232 adding machine won't print totals
For mine to print I have to hit either the subtotal key, or the total key. (# and/or * )
Jun 05, 2013 | Universal Office Adding Machine/Calculator...
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
Setting date and time, I put in correct date but doesn't stick ,
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Apr 08, 2010 | Canon MP-11DX Calculator
I need to change the sales tax rate for my cash register.
Please find below the solution:
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Mar 18, 2009 | Casio Parts Cash Register PC Desktop
Canon P170-DH
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Jan 10, 2009 | Canon P170-DH Calculator
Printing Totals
The asterix (*) next to the big fat plus key prints the running total.
Just figured that out. Why doesn't Canon have a downloadable manual for this thing?
Oct 23, 2008 | Canon P23-DHV Calculator
How can I get this calculator to not print[-- I just want to use without paper?
P/NP means Print or no print. I know fairly complicated. Hit the 2nd button then NP. This key is also known as the M+ button. Hint lay off the grass.
May 28, 2008 | Sharp EL-1611P Calculator
Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Jan 05, 2008 | Casio HR-100TEPlus Calculator
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Nov 30, 2007 | Canon P23-DH Calculator
Sharp EL-1750PIII Calculator Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
