Question about Dell Dimension 2350 PC Desktop
I reinstalled the operatiing system & it won't to the internet. Doesn't show an network conn ection in the device manager just a yellow question mark by the ethernet controller. I've installed all the drivers.
    Scholar:
  • 128 Answers
Here are the stpes that you can try..Go to Device Manger select ethernet controller, then right click, select Properties and then select Uninstall. After this re-install your Ethernet driver. The yellow question mark means that the computer is not detecting the device.
Posted on Sep 10, 2010
Internet won't connect
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima
Apr 19, 2013 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
There is a yellow exclaimation on my network adapter in device manager
This not necessarily cause for alarm. You can try to reinstall the driver for the device to see if that clears out the exclamation mark and, most cases, it will.
The exclamation mark simply means that Windows has found some sort of problem with the device. Double-click the adapter and see what the Device Manager's status says about it. This can, generally, point you in the right direction on what is wrong.
If reinstalling the driver doesn't work then post what the Device Manager status is for the device.
Jul 04, 2012 | Acer 91.AB370.001 Network Adapter
Connect via wireless router, but when i click on internet explorer it says internet explorer cannot display webpage
this could be a driver problem or it might be firewalled
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps
Sep 18, 2011 | Computers & Internet
I uninstalled the wireless network adapter ( accidentally ), How can I install the adapter again. my OS back-ups won't work. I downloaded the drivers and ran, still no adapter in Device...
Plug in the Ethernet cable to the PC, go to device manager via the control panel and your wireless network adaptor will show there (under other devices) with a yellow question mark next to it. Right click it and select update divers.
Oct 05, 2017 | Computers & Internet
Acer x1300 - reinstalled vista and have three yellow warnings in device manager: Coprocessor, Ethernet controller, sm bus controller? How do I fix?
Easiest way would be to use a seperate computer and download the drivers onto a usb stick and use that to install the drivers. You can't download straight to your computer since your Internet won't work (Ethernet Controller isn't installed) You can also burn a CD if a USB doesn't work.
You can get the drivers from here.
http://driverscollection.com/?H=Aspire%20X1300&By=ACER&SS=Windows%20Vista
Jun 05, 2011 | Computers & Internet
I got a couple of virus infected my PC a week ago (Essential Cleaner & MS Removal Tool). I had to download instructions on how to remove such virus on the internet. I managed to remove the first virus...
Even if you remove a virus, most of the cases, the damage cannot be repaired. Remove the sound driver and install it once again. If that doesn't work, you should consider reinstalling the OS.
May 24, 2011 | Microsoft Windows XP Professional
My PC is Home Windows XP and it was working well untill the sound disappeared. I have tried to solve this problem as there is small icon of what is called Sound Manger without success.The buttons of the...
http://www.realtek.com.tw/DOWNLOADS/downloadsCheck.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Here is a link to Realtek's audio driver download. It works perfectly in windows xp!
Dec 15, 2010 | Computers & Internet
Device manager problem!
It sounds like Windows is not recognizing the digital signature of the drivers. If they are the current Dell drivers, you can simply ignore the flags.
If you are bothered by them, you can try removing the device from the D.M. and re-installing to try to resetting the digital signatures. (this may not remove the flags)
Mar 26, 2010 | Dell Inspiron 1501 Notebook
After a crash I reformatted the hard drive and now it won't conne
Check to see if the software drivers are loaded for the network adaptor. Go to "Device Manager" and look if any yellow or red alerts are being displayed next to network adaptors. Double click on the network adaptor and a window will pop open telling you about the error. You can access the "Device Manager" by going to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column, (assumption – laptop has Windows XP).
If you need drivers, go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag", (serial number) of the computer. Dell keeps a listing of drivers for every customer's computer they sell.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 05, 2009 | Dell Latitude D610 Notebook
Dell Dimension 2350 PC Desktop Logo
194 people viewed this question
Alun Cox
