Question about AOpen AX4SPE-N (91.8AT10.701) Motherboard
Pretty basic issue. Will not POST, no beeps, no indication what's wrong. I don;t have the manual, so I'm not sure what to check.
  • 11,800 Answers
Standard checks: that the power source isn't dead, that the power button is connected, that the memory or the processor isn't faulty.
If even after replacing them it doesn't start then the fault is in the motherboard - check the sources, especially the capacitors.
Posted on Sep 10, 2010
Help my dell is not displaying but the front led is showing the power light on CPU but is not displaying on the monitor and i have used working RAM on the Computer but the problem is the same, kindly help...
If you do not hear a post beep sound, then you may have an issue with the motherboard and/or processor. I suggest you either take it in for repair or replace yourself
If you hear the post beep sound, then listen for the sequence of beeps. This should indicate what is wrong with the machine. Generally(Note: these may be different with motherboard and/or bios type).
  • sequential long beeps indicate RAM issues
  • 1 long followed by two short indicate a display adapter issue
Mar 23, 2015 | Dell (E210882) Motherboard
Post beeps 4 times
All motherboards are different and have different beep codes. You should look up your motherboard model and find the manual somewhere online where you can find out what it means. Source(s): @runningAround
No it doesn't. BSOD is strictly a Microsoft thing. If the hard drive was failing, it wouldn't display anything.The four beeps indicates that something is wrong with the video card. First, open the computer and pull the video card out and then reseat it. Sometimes, heat from the slot can loosen the contact between the card and the slot. The heating and cooling can do this, by expansion and contraction of the slot. You may have to try reseating the card more than once, check all your connectors and make sure they are tight.
If, after doing this, you still get no video, you can pretty much be sure the video card is dead and you have to buy a new one.
May 17, 2011 | Computers & Internet
I have no screen on my acer aspire 9300 it powers up and then I get three beeps the first longer than the second two and then just a blank screen?? Please help
When you hear some beeps before a computer boot it means that it didn't pass the POST (Power On Self Test) phase. Taking note of the sequence of the beeps and checking the manual should tell you the reason, for example bad memory, no HD found, bad processor, etc....
Looking at your model manual here below the codes are not indicated but Acer ask to call their tech support (see page 43)
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS%209300_7000%20User%20Manual.pdf
Anyway the 1 beep long and 2 short means 1 long, 2 indicate a video error and the Bios cannot initialize the video screen to display additional information.
You may have to replace the video card.
regards
Mar 16, 2011 | Acer Computers & Internet
How will you know if the processor is still working?
Finding Out the CPU condition whether its working or not
  • 1
    Turn on your PC and listen for a beep. Your computer runs a diagnostic upon startup called "post." Post checks for the basic requirements for your system. This includes RAM, processor and video functions. If those three basic elements are working properly, you will hear one beep from your computer's speaker and you can be assured your processor still works.
  • 2
    If you hear multiple beeps, count the number of beeps you hear as this will help you determine if your processor is functioning properly. If you are running Phoenix BIOS, make sure you count and write down the beep sequence.
  • 3
    Consult your motherboard's BIOS instruction manual; there will be a section on the "post" startup. Five beeps means a processor error for most standard AMI BIOS systems. The number of beeps you here will tell you the problem your computer is experiencing that is preventing it from booting up. Once you know how many beeps to look for, you can safely determine if your CPU is still functioning properly.
  • Jan 19, 2011 | Intel Pentium 4 2.40GHz 512/400/1.5V...
    My computer is making continuous long beeps and i dont know what it is can anyone help ?
    These are bios beep codes and indicate an errror condition with your system. It could be faulty or loose ram modules, hardware or device conflicts or failures. Exactly what is wrong is indicated by the sequence of beeps, but the code is specific to the bios manufacturer, so you'll need to know what kind of motherboard or bios you have installed.
    For further instruction to help diagnose your computer's problem, see articles here, here,
    here, and here.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Sep 12, 2009 | Computers & Internet
    Fan running, HDD light solid, no display
    I assume there are no post codes (beeps)?
    Pull everything including the video card, leave only the RAM and CPU installed.
    Try powering it on, You should hear a long beep, then some short ones to tell you the video card wasn't detected.
    If you still don't get any post beeps, try resetting the BIOS, and re-seat your RAM.
    If it still doesn't post it could be a system board mounting issue, bad system board, bad RAM, bad CPU, or bad Power Supply
    Jun 24, 2009 | E-Machines T2240 PC Desktop
    Gateway laptop beeping
    Check with the gateway beep code if you acknoledge the POST error beep you ear Or contact
    Jan 12, 2009 | Gateway M350 Notebook
    Beebing tree times
    Louise -
    Although the memory may be working okay in another system, the three beeps at post still indicates a memory(RAM) problem. Your motherboard uses AMI BIOS, as indicated by the product specifications on the Asrock website; In the post-error code listing, three beeps is a memory issue.
    Check and make sure you have compatible memory for the motherboard; and if possible, test with new or alternate memory sticks.
    If new memory doesn't resolve the issue, I would say the RAM slot(s) is damaged, which would require totally replacing the motherboard.
    Hope this helps!
    -thinstatic
    Jun 13, 2008 | Asrock K7VT2 Motherboard
    AOpen AX4SPE-N (91.8AT10.701) Motherboard Logo
    52 people viewed this question
    Top AOpen Computers & Internet Experts
    Michael Galve
    Michael Galve
    Matthew Spark
    Matthew Spark
    David
    David
    Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
