Question about Poulan Pe550 Gas Edger
The edger will not run with the choke on, even then it stalls out after releasing the choke
  • Poulan Master
  • 7,482 Answers
Check your fuel filter in the fuel tank,if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 05, 2010
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
It will idol when choked apon release motor revs big and stalls
So it idles fine when the choke is on but not when its off, am I correct.
When the choke is on, the butterfly on the carb is closed. Meaning that Air is restricted upon entering the carb. This is telling me you still have a fueling issue. As when the butterfly is closed, the engine is getting the optimum amount of fuel and air to burn. However, when you release the choke, you open up the butterfly on the carb mean more air can get into the carb, in turn this draws more fuel through the carb to create that optimum burn.
Yours however isn't getting the fuel it needs when the butterfly is open, meaning its getting too much air and not enough fuel. Check and clean carb, replace any fatigued gaskets and diaphragms.
Apr 26, 2016 | Echo Used Trimmer Gt200r Outer Drive Tube...
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
Fuel Adjustment for a Homelight Edger
Does it operate well with the choke full off or do you have to have it partially choked to get it to run? Also, how old is the gas and have you tried to run any cleaner through it b/4 messing around with the carb? Your local auto parts store sells a product called Sea Foam Cleaner. You can add that accordingly with your oil and gas mixture to help clean out any dirt in the carbs.
Aug 08, 2009 | Homelite Consumer Products Tiller...
Stalls out at full throttle
Has the air filter been removed, damaged, or the airbox not seated propelry on the carbs neck, this would cause it to run lean hence requiring the choke to be in operation all the time. Have you tried fresh fuel?? This goes stale after a while. I hope this is helpful, Ian
Jul 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Stalling out
Generally with two cycle engine as soon as the engine starts the choke needs to be moved to the off or open position. Some chokes have a middle position that lets the motor run until it is warm enough to move the choke into the open position. In other words weather it is a two or four cycle engine the choke is used only to start the engine. If you unit is newer and still does not run well with the choke in the open position, you may need to adjust the hi-speed circuit to a richer one.
Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Will start (briefly) on full choke and then when I switch the choke to half choke the engine stalls out??
I had the same problem and was able to fix it by tightening the two allen-head screws holding the cylinder to the crankcase. These screws had vibrated loose and was letting air enter the combustion chamber causing the mixutre to be too lean to run. This does require some disassembly but the entire job only took about 30 minutes.
Jun 05, 2009 | Poulan Pe550 Gas Edger
Stalling
  1. Check fuel mixture ratio.
  2. Carb needs cleaned and/or adjusted.
May 03, 2009 | Garden
Poulan Pe550 Gas Edger Logo
148 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
