Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
EE6 - Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
  • 674 Answers
There are several possibilities for this error.
1. You're out of fuel.
2. You're not getting any fuel to the burner.
3. The high temperature limit is activated.
4. Your flame rod (sensor) is dirty.
The noise the pump makes is a give away for a fuel problem. If it's not getting fuel it will make a loud ticking or thumping sound before the heater cuts off. If it is doing this, you need to check your fuel filter if you have one close to your outside tank. You should also check the strainer located on the right side of heater in the fuel sump. Two screws hold the cover on. Turn off the fuel at the tank before cleaning the strainer. You should have some old rags or something to catch the kerosene that is going to come out. The high temperature limit should reset after it cools, but you should find out why it overheated. Cleaning the circulation fan may help with that. Lastly, look at the flame rod and make sure it's not dirty (soot). You can clean it with some steelwool or fine sandpaper. Let me know if this doesn't help and we can go from there.
Posted on Sep 11, 2010
For the ans. of 0.000026316*10^6 i should get 26.3 but i get 263. I put in ee6
You're probably multiplying by 10EE6, which is 1EE7.
Press . 0 0 0 0 2 6 3 1 6 EE 6
or
. 0 0 0 0 2 6 3 1 6 * 1 EE 6 if you want to do the multiplication.
Note the 1 before the EE on the second, not 10.
May 02, 2011 | Texas Instruments TI-30XA Calculator
Our 73 stay on as long as it is being primed so you have keep priming it to keep it on, then turns off 1 min after we stop priming it either reads ee2 or ee6
This site http://livesupport.maybenow.com/Rinnai/Rinnai-Toyostove-Direct-Vent-Heater-Laser-30-pr254029 handles prime issues directly for the unit. I would recommend contacting an individual in person that can assist you with the prime issues. This is a very sensitive issues which is best handled by having the problem fixed in person and not via email, chat, phone. (Lots of Danger factors)
Jan 26, 2011 | Rinnai Toyostove Direct Vent Heater:...
After having our toyostove laser 30 serviced it started building up a large icicle below the exhaust (this was hardly noticed before). It also generates an ee6 code when it runs on high. It ignites and...
How long is the exhaust pipe on the inside of the house? Is it covered with a cloth sock? The EE 6 is probably from air in the fuel line. I am a little confused by the term "our downstairs heater". Do you have a lifter for the L30?
Tom
Dec 02, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I keep finding my Lazer 56 off, with the code EE6. What does that mean?
This could be several things. It could be a problem with fuel flow, the high temperature limit is activated, or a problem with the flame rod. Start by checking your filter at the barrel and the strainer in the fuel sump. If you hear a ticking or thumping noise before it cuts off, you are not getting fuel to the fuel pump. Next you can clean your flame rod with some steelwool or fine sandpaper. Lastly, make sure the circulating fan is running and nothing is blocking the air to fan. You can also clean the fan blades if they are dirty.
Sep 29, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Getting an EE6 after relocating heater. Have fuel
EE 6 usually indicates a fuel problem. You said you just moved the heater. If the fuel pump is making a loud ticking sound it means it isn't getting any fuel. Try pressing the fuel reset located on the lower right side of the heater. There is a float in the fuel sump that can get latched up so that it will not let any fuel into the sump if the heater is moved or jarred or the sump gets too much fuel in it. You say you have fuel, do you mean in your barrel or is it coming out the fuel line behind your heater? It is possible you have an air bubble in your fuel line that you need to get out. Hope this helps.
Jan 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
EE6
EE 6 is a fuel line problem. Check your filter and the strainer in the fuel sump. You can find a manual at www.toyostove.com. What type of fuel do you use. If you use fuel oil you may need to clean your fuel pump and the copper line from the pump to the burner. Hope this helps. You can contact me at nitensheaterservice@embarqmail.com.
Jan 11, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My laser 30 quit working suddenly last weekend. It has given error EE2, EE6 and EE13. What should I do?
Get it tuned. Sounds like it is plugged up.
If it has been more than 2 years since the last tun-up.
Oct 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 56 EE6
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 09, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove, Lazer 30 model
EE22 is a lockout code.
Unplug unit for 30 min.
You need to findout why you still get EE2 or EE6
Check fuel and filter
Still have problems call me I'm in North Pole
Dave 4889179
Apr 10, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
Feb 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
209 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
