Question about Coleman Electrical Supplies
I've just acquired a Coleman Sport 1600 generator made by Powermate. It's used but hasn't been run for a few years. It starts fine but when I move the choke after warm up the engine starts to surge (hunts). I can't find a manual. Any suggestions on possible causes/solutions? I did have to clean out the carburator as the float was stuck open but that problem is now fixed and the generator starts easily. The only problem I have now is the surging situation.
  • 11 Answers
SOURCE: Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Posted on Sep 10, 2008
  • 15 Answers
SOURCE: engine surge up and down
Cleaned the carb again and set idle stop screw up
Posted on Nov 18, 2008
  • 4 Answers
SOURCE: Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Posted on Jan 02, 2009
  • 195 Answers
SOURCE: Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Posted on Jan 23, 2009
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000W Generator Stopped Suddenly
Sounds like you threw a valve push rod, or broke a rod
May 06, 2013 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
Coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Jan 18, 2010 | Coleman Sport 1850 Generator
Coleman Powermate 6250 generator - shut off generator at 11pm after v4 hours normal use. At 5am, wouldn't start, pull rope wouldn't move to start. A few hours later while draining oil found mostly gas...
the usual reason is a stuck float in your carburator , can be caused by dirt/rust etc , remove carb bowl and clean , there is also a very small needle valve which is attached to this float ( metering needle ) these can leak.
if all else fails always turn off the fuel supply to the generator whilst not in use
Oct 21, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 8750 will not generate electricity.
I had a similar situation with a friends generator. After sitting around unused for a few years it would not generate because the residual magnitism was weak. I plugged a light into it and by using the throttle arm I breifly ran up the RPM and the light came on. DO NOT MAINTAIN THE HIGH RPM FOR MORE THAN A FEW SECONDS.
Feb 25, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Electrical Supplies Logo
499 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
