Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Vacuum turns on but the brush is not rotating
  • 377 Answers
Most likely a problem with the drive belt or the beater brush. Either the drive belt is broken or the beater brush is frozen due to debris. If you can not turn the beater brush by hand, it should be removed and cleaned well. The ends of the beater brush that hold it into the vacuum should be lubricated with some WD40 and moved by hand until they are free. Once the turn freely, replace the beater brush. If the drive belt is broken or missing, it needs to be replaced.
Posted on Sep 10, 2010
  • 126 Answers
SOURCE: Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
SOURCE: brush and belt no longer rotating
My vacuum does not have suction and the belt is no longer turning the brush
Posted on Oct 24, 2008
SOURCE: brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Posted on Dec 12, 2008
  • 120 Answers
SOURCE: stopped running
orecks have a plastic fan inside and everything you pick up hits it, sometimes things can get stuck in there or break the fan locking up the motor. With the machine off, poke around where the dirt goes into the motor, behind the roller and see if you can pull anything out.
Posted on Jan 12, 2009
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
Brushbar not turning
Hi there, it's Jack at Dyson.
DC03 doesn't use a traditional user-replaceable belt. Instead it has a brush control clutch mechanism which allows you to turn off the brush bar when cleaning hard floors and delicate rugs.
If the brush bar doesn't seem to be rotating, it's worth double-checking you have the brush control set correctly. When the machine is reclined into the normal vacuuming position, the brush control should move to the Drive/On position:
Please note, as a safety feature the brush bar will never rotate when the vacuum is standing upright.
If you're confident the brush control is in the correct position, but the brush bar still won't rotate, please give our freephone UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Sep 16, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Brushes not rotating
If your unindentified vacuum cleaner is an upright, the belt may be stretched and unable to rotate the roller brush. The roller brush ends could be clogged with debris, preventing it from rotating freely. The solution is to disconnect your vacuum cleaner from the power and turn it upside down for inspection. It may be necessary to remove the roller brush and remove the end caps to clean inside. Replace any worn parts
May 07, 2013 | Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
When I turn on the rotating brush the vacuum makes a horrible sound. How do i fix it?
ok, after long call with thech support I found it is bad bearings in the roller brush. So that needs replaced.
May 21, 2010 | Bissell Upright Vacuum - The Pet Hair...
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
My dyson vacuum brush bar will not rotate and the belt is not broke. The hand tool works fine. What is wrong?
I took the plate off and cleaned up the vacuum brush bar. Since the belt was not broke I knew that was not the problem. I know when the setting is bare floor, the brush bar will not rotate. That was not the problem. I just keep turning the knob from bare floor to carpet, several times. The setting must have been "off" just a bit because after several times turning it, it must have reset in the proper setting. The brush bar did start rotating just like normal.
Nov 21, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Rotating brush will not turn on my Dyson DC07
Jan 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
298 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
