Question about Whirlpool Dryers
Not enough lint/ not drying/ blockage? Cleaned the vent from outside also purchased a long brush and did the inside of the dryer, still not drying
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
My dryer heats up but does not dry clothes. I check ventilation and lint trap, there is no buildup. what could cause it to take forever to dry clothes?
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
Dec 16, 2012 | Kenmore Dryers
Kenmore gas dryer not getting hot enough to dry
If inside of drum gets hot suspect first somewhere between it and the place where it vents outside a blockage---Lint can do this and be hard to find and also represents a fire hazard, each year there are hundreds of fires caused by lint buildup that catches fire
Dec 09, 2012 | Dryers
I have a Frigidaire stackable full-size washer/dryer. I don't have the model number, but it is about eight years old. The dryer does not get hot enough to dry even a small load well.
When was the last time you cleaned out your vent? It should be done every 1-2 years to prevent build-up of lint and possible blockage. Also make sure your outside dryer vent flap is not stuck closed or clogged. I use a plumbers snake to twist inside the vent and clean out the lint. It makes a huge difference in drying time. Also disconnect the vent from behind the dryer and check for lint build-up inside the back of the dryer itself. (Be sure to unplug the dryer before you do this!) When you push the dryer back, be careful not to squish or pinch the dryer vent if it is a flexible foil or plastic tube. These are the easy fix-it's. Try them first before resorting to more expensive trouble shooting. Douglas
Sep 06, 2010 | Frigidaire Dryers
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Clothes are not drying completely - even when I
before you call a repairman. check 2 things vent hose behind dyer for a kink or a restriction ( lint build up.) if your vent hose goes straight out make sure nothing is clogging the vent or the flapper outside, if vent goes up and through attic then outside vent system may need to be cleaned out. lowes sells a cleaner brush extension that you can buy and snake through your vent . this should be done yearly. we get service calls on this all the time and 9 out of 10 its not the dryer, but a ventilation problem, if the hot humid air cannot be released outside the dryer cannot dry your close. hope this helps. p.s their is proffesional companies that strickly do dryer vent cleaning if you would not rather do it your self.roughly 65-145 dollars depending were you live and who you use todo it.
Sep 17, 2009 | Dryers
Dryer must be run several times before clothes will dry
Hi Herrony,
You have a ventilation issue. Somewhere in the internal (inside the wall) vent plumbing is a blockage. This keeps air exiting. Check this website for more information. Before calling a vent cleaning service, locate the dryer exhaust on the outside of your home and check it for obstructions (lint, bird nest, etc...).
Thanks for trying FixYa! (and if this solved your problem, don't forget to log back on and rate it, OK?)
SG
Apr 02, 2009 | Whirlpool Dryers
Condensation build-up in the dryer drum, clothes remain very damp
You deffinately have some sort of blockage in your exhaust vent, most likely in the wall. Check the outside vent on the outside of the house. The air should be blowing pretty hard. hope this helps. Dave www.washermd.com
Dec 17, 2008 | GE Profile DPSB619ED Electric Dryer
Too long to dry my clothes
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Suggest going to Lowes and purchasing vent cleaning kit. Read instructions CAREFULLY. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
May 03, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer takes longer
check the humidity sensor not working
Mar 09, 2008 | Dryers
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
