Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I have a Badger 5 1/2 HP garbage disposal. When I turn on the power switch it just makes a humming sound but doesn't engage. Is there a reset button somewhere on the unit that might need a reset? Thanks!
  • 377 Answers
There should be a reset button (circuit breaker) on the bottom of the unit. It sounds more like the blades are stuck. Pull the plug on the unit and use an allen wrench on the manual blade turner on the bottom of the unit. If the blades are stuck, you will have to try and loosen them with the allen wrench. If you do get them loose, the question then is what was holding them. Could be debris in the ISE or something broken like a blade. Keep the unit unplugged when working on it.
Posted on Sep 11, 2010
  • 1 more comment
  • pwillitz Sep 18, 2010
    Thank you VERY MUCH for the rating you gave me!!
    I greatly appreciate it.
  • herbie6200 Sep 22, 2010
    The blades on my disposal weren't stuck but rather making a clickety sound when I would run it, kind of like a spoon was in it but I couldn't find any foreign (or familiar!) object in it. I used the allen wrench on the bottom of the unit and turned the blades manually, which sounded like two pieces of sand paper rubbing together. I poured some Pine Sol into it, thinking that the oily substance would help the blades turn more smoothly (I also used some shampoo since it's thicker and was conveniently under the sink). I continuously searched for whatever might be in the disposal and would turn it on for an instant to see if it would work without the rattling noise. I continued turning the allen wrench at the bottom of the disposal (clockwise and counterclockwise) until it magically turned without the sandpaper noise. Then, I turned on the disposal and it worked. Who said a woman can't get the job done! Thank you for the convenient, online help, FixYa.
  • pwillitz Oct 01, 2010
    HEY!!! Nice job there. One thing I did not mention in this solution is the fact that the ISE needs to hang straight down from the sink. When an ISE is installed, the basket is set on the sink and the ISE hangs from it. If the drain line(s) to the ISE cause it to be pulled a bit off center when they are later installed, it is very likely the blades will bind on the basket which could cause the clicking sound you referred to.
    BTW, did you count your silverware? :)
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
Disposal hums, but doesn't work. blades turn freely, as well asthe motor with a wrench- with no pressure?
Copy following link for disposal troubleshoot, and replacement tips:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Sounds like disposal motor has overheated and shorted.
Fortunately today's disposals are fully contained, and did not cause fire.
Replace disposal.
Mar 16, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I get power through the reset button. No humming, no nothing. Is it a bad motor?
If i understand correctly, you tested the wires where they connect to the garbage disposal.
Those wires connect before the garbage disposal reset button.
If the reset button is locked in, then the reset is not popped out.
If reset will not reset, then the popped-out reset will push in but not click down.
If the reset is clicked in, and you hve 120V on the line, and the garbage disposal doesn't make any noise, then the motor is bad.
There are no replacement parts for garbage disposal.
Oct 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 1/2 HP and it makes a humming sound when I turn the on switch. I've tried the reset button and it doesn't help. It doesn't appear anything is stuck. Any advice? Thanks!
Hi, Sounds like the motor just died
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposle makes a humming noise when turned on. InSinkErator Badger 5, 1/2 HP Garbage Disposal
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
May 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
BADGER GARBAGE DISPOSAL NO POWER
Have you checked the circuit breaker on the disposal itself? In the bottom there's a little button that resets the circuit breaker. press it in and see if that works. If the disposal is still jammed you should hear a hum.
Dec 28, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
354 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
