Question about SkyGolf SkyCaddie Handheld GPS Unit
How do i change battery on skycaddie 2.5 - SkyGolf SkyCaddie Handheld GPS Unit
I can't get my skycaddie to move.It's like it's frozen
Hi Dorothy,
The first thing you should do is remove the battery. After replacing the battery make sure it is completely charged. After that, turn your skycaddie back on and it should work normally. Make sure that you are outside with an unobscured view of the sky. When you secure access to satellite your GPS should record your movements larger than 50 yards or less. I would use my phone to verify my exact location.
Cheers,
Dr. Bob
Jun 11, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
Tip
Loss of GPS Signal and Yardages
It is often thought that a GPS device like the SkyCaddie should keep constant uninterrupted view and connection to the satellites, thus always giving accurate yardage information. This is true of cellular technology, indoors or out, etc, but not for a GPS device like the SkyCaddie. A clear, unobstructed view of the sky must always be maintained for optimum performance. Here are some other tips:
1. When going to play golf, the SkyCaddie should have a fully charged battery and should be allowed to search and acquire satellites for at least 10-15 minutes, prior to play. During this time, the device should be stationary. Many people power the device on then head straight to the course. From that point on, the yardage info you get may be off or may not show at all.
2. Is the golf course you are playing in need of an update? It's good to plug your SkyCaddie into your computer and allow it to sync with the SkyCaddie desktop software. You will receive updates to the device if you do this periodically and you can view your course list to see if any of your downloaded golf courses should need an update. An unupdated golf course on the device can cause yardage problems.
3. Placing the SkyCaddie in your pocket during the game, placing it in a golf cart cup holder, tall trees or heavy shrubbery, hilly terrain, very overcast cloudy days, etc., all can impede satellite acquisition and yardage accuracy.
4. Internal issues. Most SkyCaddie models may have an outward antennae view, but there is also an inward antennae connection that could be compromised. If this is true, the user will not know this, as this type of issue is internal and will need to be sent in to the company for repair, contact them to have this done. This can also be the source of why a device never seems to acquire satellites and/or give accurate yardage information.
on Aug 12, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
My SkyCaddie SG5 turns off on its own on the course and is slow to update yardages. It worked perfectly for a year and then I noticed the screw that hold the battery cover closed was missing. I replaced...
i have the same problem, I turn it on to play and about 2 min later it shuts off. i plugged it into the wall and it passed the 30min trial test. when i removed the back a small little half circle piece came out. not sure what to do??
Aug 28, 2010 | SkyGolf SkyCaddie Handheld GPS Unit
Cant get past personal info page to activate skycaddie golf range finder
Prior to activating your SkyCaddie, you will first need to install a simple software program to your Windows-compatible PC. This software program, referred to as SkyCaddie Desktop, will allow your SkyCaddie to communicate with the SkyGolf website. This program allows you to DirectConnect with the SkyGolf website, so you can personalize your SkyCaddie, download courses and periodically update your SkyCaddie’s software. NOTE: If your computer is protected by a firewall, it may need to be set up to allow our SkyCaddie software programs to access the web. If your firewall software displays any warning messages during the activation process, simply indicate that you wish to allow access. if the software is not installed the unit will not get activated Activating Your SkyCaddie Within 30 days, please register your SkyCaddie, create a “My SkyCaddie” online account and select a SkyPlayer Club Membership Plan by going to the SkyGolf website at www.skygolf.com. Click the “Getting Started” link for information and instructions to complete the process. During this process you will be asked to create a user name and password for your online account referred to as “My SkyCaddie”. The “My SkyCaddie” online account offers a full range of member services, easy access to download courses, support and more. In addition to creating an account, you will be asked to select a SkyPlayer Club Membership Plan that best fits your needs. click this link directly to get more details http://service.alan-electronics.de/golf-electronic/sky-caddie/SG-2-UserGuide.pdf check out on page number 8 of the link to get details on this isue. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 19, 2009 | GPS
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Sky caddie will not sync. error reads your SkyCaddie colud not be found.
plug in your connection cable to the back of the skycaddie with the cord going down towards the battery, not up. This should fix the USB recognition issue.
Jul 26, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Sg4 skycaddie
How long have you had this battery for this device? Is it the same battery you have had in the device since date of purchase? Since I don't know the answer to these questions, if the battery is over 12 months old, you need a replacement, quite possibly, even if it is indicating a full battery. The other side of the coin is if it is NOT the battery, it could unfortunately something has gone wrong internally and you may need to send the device in for repair. Try leaving the device's wall charger plugged in and then power the device on and select start to see if the device will then automatically shut off. If it still shuts off, there is an internal problem with the device. If it does not shut off while the charger is plugged in, but shuts off when the charger is NOT plugged in, sounds like a battery issue.
Sep 07, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
SkyGolf SkyCaddie Handheld GPS Unit Logo
370 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
