Question about Bissell 9200 Upright Vacuum
The beater won't turn easily- burning out and breaking the belt.
  • 377 Answers
The beater brush needs to be removed and cleaned of any debris. The ends of the beater brush that hold it into the vacuum need to be cleaned so they can be moved by hand and lubricated with a bit of WD40. This should prevent the belts from burning out.
Posted on Sep 10, 2010
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
I purchased a Eureka C4910 last year and have a question that I am hoping you can answer. There are two motor actions with this vacuum, 1) the vacuum suction, and 2) the beater bar. The action of the...
Good day!
Normally when the motor is easily moved back and forth means that it have a proper lubrication,proper alignment and no clogs.
When the motor and the belt is OK the problem could be on electrical wiring and switch.
If found electrical switch burned out you need to replaced it because when the switch is burn the contact of that switch is open even you turn it ON.that's why the motor is not function because the voltage is not pass through the circuit because of open switch.You need to replaced it.
And check some fuses if any and other burned electrical wire.Replaced it also.
Thank you and don't forget to rate my answer.
May 28, 2011 | Eureka C4910 Bagged Upright Vacuum
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
Smells like burning rubber when I turn on my G6 Kirby vacuum.
You must take of the plastic ends from the wood beater bar and make sure the metal axels are not wound up with hair. I did this monthly with 4daughters
Feb 15, 2010 | Kirby G4 Bagged Upright Vacuum
We keep changing belt on tesco vcu007 but it breaks again as soon as we turn it on
I am unfamiliar with this make and model, but assuming it is an upright vacuum cleaner type design, something must be stopping the brush/beater bar from rotating. When it is then switched on, this immeadiately places a huge strain on the belt which then snaps (quite often accompanied by a burning rubber smell)
If you still have the user manual, this should show you how to remove the bar, clean it and check for any foreign objects preventing the bar from turning. If not, beater bar removal isnt normally too difficult to work out.
Hope that helps.
Dec 17, 2009 | Vacuums
I HAVE A KIRBY AND IT KEEPS BREAKING AND BURNING BELTS.
Hello, Check this guide to be sure that your brushroll is in correctly. Follow it step-by-step and it should help of your brushroll spins freely. If it doesn't, there are new brushrolls available through the links in the guide as well.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jun 06, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt burning
the beater bar probably needs to be removed & cleaned. the shaft & bearings get bound up with hair, string, etc.. with the belt off the bar, it should spin fairly easily. if it's hard to turn,(belt off) then it's bound up.
Jun 14, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 9200 Upright Vacuum Logo
43 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
