Question about Bosch Dryers
Dryer produced a big spark by air exhaust, now it has power and when you try to start it, it only hums. I have taken the back off and looked for a trip switch but was unable to find one.
  • Bosch Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the motor went bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
I have a 1994 ford escort and it's not getting eoungh power I've change the battery, sparks plugs and the alternator don't know what else to do please help
Did you check the timing? If the timing is off there will be a reduction in performance and power will be greatly reduced. If the engine is "pinging" or "knocking" under heavy acceleration, your timing is advanced, and pre ignition is occurring (that's when the spark has ignited the fuel in the combustion chamber prematurely), resulting in a knocking sound. When the piston is compressing the air/fuel mixture within the combustion chamber, the spark plug produces a spark from current it receives from contacts closing in the distributor cap. (Where all the spark plug wires are plugged into) if that spark come BEFORE the piston finishes it up stroke or compression stroke, the piston is then being slowed down from the kinetic energy produced by the exploding fuel. Thats where we loose our power. Idealy, the spark should come AFTER the piston has rotated over the top of its stroke, It has reached its limit in compression and is on its way back down then the spark should ignite the compressed fuel, thus giving the piston an additional "shove" back down to start its "Power" stroke, once its reached the bottom of the power stroke (stroke #2 of 4) it is then carried back up for the "exhaust" stroke pushing the burnt fuel out of the combustion camber and into the exhaust manifold, one it has reached the top of that stroke it begins its journey back down to start stroke number 4, the Intake stroke. Drawing in air/fuel mixture to again be pushed back upward to compress the air/fuel, and repeat the process over and over again. Now that I have thoroughly bored you to tears, Yeah, check the engine timing, if its not the timing it may be a vacuum leak.
May 11, 2015 | Ford Cars & Trucks
Tip
How to Diagnose Maytag Neptune Dryer Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Level</span> </li></ul> <ol> <li> 1 Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.<br /> </li> <li> 2 Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.<br /> </li> <li> 3 Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.<br /> </li> <li> 4 Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.<br /></li></ol><span><a href="http://www.ehow.com/how_5557946_diagnose-maytag-neptune-dryer-problems.html#ixzz19V7gQpV4"></a></span>
on Dec 29, 2010 | Dryers
Power indicator lights up but there is no power
Remove exhaust hose. Clean out lint. Remove back of dryer. Clean lint out of air flow system including lint and heat unit(coils). Try dryer. Is heat element glowing red hot? If not, replace heat element. They burn out intermittently and need lots of air flow to have good life. Clogged lint traps shorten life cycles. Definitely a DIY project. See youtube for general process.
Jan 09, 2014 | Whirlpool Dryers
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
My Maytag natural gas dryer (model SDG505DAWW) will not dry. When I start the dryer initially the air coming out of the exhaust is warm but after a few minutes only cool air come out. So far I have: -...
THAT IS THE GLOW COIL IGNIGHTER JUST BEFORE IT GOES OFF THE GAS VALVE SHOULD HAVE OPENED TO MAKE FLAME SHOULD BE 24 VOLTS AC TO THE GAS VALVE THEN IF SO VALVE IS BAD IF NOT CONTROL CIRCUIT HAS PROBLEM MAYBE ONE OF THE SAFTYS
Jun 11, 2011 | Maytag Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My Maytag Neptune Dryer works great with no close in it. As soon as you put clothes in it wont stay hot.
    Instructions
    Things You'll Need:
    * Level
    1. Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.
    2. Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.
    3. Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.
    4. Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.
    Feb 23, 2011 | Maytag Neptune MDG6800 Gas Dryer
    Loooking for pull cord 5hp/ 22 inch snow blower ultra by murry. My cord broke yesterday mhagansr@comcast.net
    Instructions Things You'll Need:
    • Level
    Jan 28, 2011 | Dryers
    Start/ pause button flashing 47 minutes left to cycle pushed every button will not do anything
    • Level
    5. please comment on these solution by saying how helpful
    Dec 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    Dryers Logo
    Top Bosch Dryers Experts
    Lawrence Oravetz
    MightyMikeJr
    Are you a Bosch Dryer Expert? Answer questions, earn points and help others
