Question about Bosch Washing Machines
Have a Model 100 bosch washing machine will fill but does nothing after that .Doesn't seem to wanna spin or move Drum/
  • 905 Answers
Try rotating the load size / water level selector switch back and forth. If this works, then your switch is going out. If it keeps on filling and doesn't stop, then your selector switch OR the level sensor (both located in compartment behind controls) is bad (probably level sensor).
The motor is locked out until the water level requirement is met, then the level switch allows the motor to be turned on.
Posted on Sep 10, 2010
Testimonial: "TY for your help guess i'll have to have a technican come to fix it."
  • roachpd Sep 11, 2010
    Well it jus takes water in and sits and clicks doesn't even try to move
  • Sheldon Dedek Sep 11, 2010
    Did a quick search regarding your model, and one of the disadvantages and common complaint about your washer is that cycle times can be very long. Have you tried to just waiting it out, hour or more perhaps, to see if it starts the next part of the cycle? Inconvenient yes, but more of curiosity.
I have a bosch washing machine Maxx WF1200.The machines fills with water than stops. Nothing happens. Also does not spin to release the water. What is the problem?
If the machine heats the water and finishes the cycle without the drum turning it is most likely your motor or what controls it.
Sep 30, 2014 | Bosch Washing Machines
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Bosch Nexxt 100 series front load washer will not spin. The machine will go through the entire wash cycle from wash-rinse-spin-finish but does not spin. I tried a separate spin cycle and nothing happens....
Just going on these symptoms, you may need a new control/timer.
Inside the control /timer are electrical contacts, and when your machine gets to that part of the cycle, the contacts are not closing to allow the cycle to complete.
If you have circuit board, you will perhaps need a new one of those.
If you do not, probably a control/timer assembly.
If you type "SeasPartsDIrect" into you computer's search engine, and then type your complete model number into the blank when you are asked for it, you may look at the schematic and see whether you have a control / timer or a circuit board.
God bless your efforts.
Oct 08, 2017 | Bosch Nexxt 100 Series WFMC1001UC Front...
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
My front loader fills with water, pumps and drains fine but the drum never moves or spins . Already cleaned pump, Checked belt and motor, belt is good and motor and drum spin freely.
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
May 21, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Washing machine will not spin
Are you able to see the belt? Maybe it broke. If the drum is not spinning than sometime broke that would make the drum spin. If you machine is a direct drive then there is a problem with the drive shaft.
Jun 01, 2009 | Washing Machines
Washing Machines Logo
153 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
