Question about LG Computers & Internet
A small chip in black color is missing in my labtop motherboard near to ram. how to repair this? my laptop model is lge500 and mother board no. intel nh82801hbn
  • 44 Answers
SOURCE: mother board sound driver d845glad
I believe this should work for you, it is the audio driver provided by Intel for the d845glad
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=830&DwnldID=5500&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Posted on Dec 22, 2007
  • 5 Answers
SOURCE: can i use DDR2 RAM in intel 865GBF motherboard?
NO ! you can only use DDR 1 ram (266Mhz,333Mhz,400Mhz) speeds only
Posted on Mar 30, 2008
swufabuda
  • 219 Answers
SOURCE: D865GSA intel mother board supports DDR1 or DDR2 ram
Straight from intels web site...
Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
Posted on Mar 09, 2009
the_fire
  • 432 Answers
SOURCE: intel Mother Board D815 Display Problem
If this is onboard graphics then it sounds like the onboard graphics card has died or gone so best option if it has a graphics card slot ie AGP or PCI Express then to get a dedicated graphics card and that should do the trick.
If not then there is something more sinsiter that is wrong and will be easier to get a replacement motherboard ( the exact same one or one that is similiar that will support the RAM and Processor you currently have )
Posted on Apr 28, 2009
  • 408 Answers
SOURCE: ddr 2 ram connecting to intel d101 motherboard
Well first of all, there is no "adapter".  You have to use the specified RAM that you motherboard supports.  Secondly, even if there was an adapter so to speak, it would not be beneficial.  The only difference performance wise between DDR and DDR2 is speed.  So if your motherboard supports DDR, and you had an "adapter", your motherboard would only read the DDR2 at DDR speed.  In my opinion, DDR2 is not really worth the upgrade to another motherboard just for DDR2.  If you want the biggest bang for your buck, upgrade the CPU, or put more memory in the motherboard you already have.  Hope this helps, and please don't forget to rate.  Thanks.
Posted on May 30, 2009
My 45gv mother boards display not come while i checked evrything ok
remove ram then check beep sound,its ok then update BIOS through recovery mode (no jumber)
BIOS from intel.com
OR
ram controller chip burn (near ram slot small 8 leg IC)
Aug 10, 2011 | Asrock 845GV (P4I45GV) Motherboard
Mother can not boot up. bios is damage
Hi,Thanks for using fixya,
Switch off the computer and open the pc cover.
First check the ram,and clean by eraser or with solvent and install again.If the problem is same, install the ram to another computer to ensure either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold" on off "switch for 40 seconds. Install battery again and start pc.
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.clip_image003.jpgclip_image004.jpgclip_image005.gif
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the bad capacitors, beside the processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htmclip_image007.jpghttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image009.jpghttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it. It could not be possible for all mother board.clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
3. Remove bios chip from base, clean with solvent and install it proper again.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blink with a long times or not.
If the floppy drives led light on, download updated bios your Intel mother board,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmos jumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNow switch on motherboard, hope, through these processes,should recover the mother board.
If the problem is same, try to install a graphics card. For same problem I will recommend you for new motherboard.
Hope this helps,.
Thanks for using fixya.
Feb 18, 2011 | Gigabyte GA-K8NE (04719331711023)...
Mother board is hang while formatting.Intel PENTIUM-4 865GV CHIP MOTHER BOARD Motherboard
kindly clean the ram and if there is more then 1 ram in motherboard removed that and try installing with single ram. also check the fan is working fine and .the heatsink in not too heat. chek the media cd also .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 23, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How to find my motherboard type and model number
If you do not have OS yet,...
1. Try to open the CMOS Setup, it is by using delete, F2 or the bios provided key that shows in boot, you will see some information there.
2. Try to open the case, using screw driver, and flash light, you will see the brand name on top of some IC heat zinc (video ic) at the center, the model is usually besides processor..
Nov 30, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard: RAM IS NOT WORKING. SUPPORTING RAM REQUIRED, CAN Y...
*********** supports DDR1 type Ram, you can easily get it from the market. Just ask the retailer to give you the DDR1 Ram, they will ask you how much memory of Ram you want. There are 256Mb, 512Mb, 1gb, 2gb, etc.. the more the better and this motherboard supports upto 2 gb, but some newer make of this motherboard miht have been changed.
May 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Missing mother board cd
enter in your motherrbord manufacture site,and send a request to send it to you
Jan 12, 2009 | Intel Motherboard
No display in a board
hello
the beep is due to ram
try to remove ram and insert again while power is off
Nov 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Display
I have Intel Jetway 945 Mother Board, I checked the Processer and Ram, And SMPS it is working properly, but I am facing display problem.
Oct 29, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
52 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
