Question about NetGear WGT624 Wireless Router
Is there a reset on my router? It won't start.
Yeah you can see that at the back portion of your router...just long press that about 30 seconds.
Posted on Sep 14, 2010
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
Router suddenly won't set up wireless connection.
reset ur router now connect to ur router using a wired connection now setup ur router...r use network magic to assist http://www.purenetworks.com/download/ if this help vote.
Sep 12, 2011 | Linksys WRT160N Wireless Router
My password won't work?...and it won't open...what would i do ??.the reset button also wodl'nt work?/
if the reset button wont work better to replace the router. But before replacing try the following steps first to reset your router.
Step 1: Plug the power of your router wait until the lights are fully initialized.
Step2 : Reset your router by pressing the reset button or hole with atleast 5-10secs.
Step3: Open a browser (ei, IE Mozilla or Google Chrome etc.) and type the specified IP address on the address bar.
Step4 Then type the username : Admin password : 1234 or leave it blank.
Hope it helps.
Sep 09, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Belkin54g router will not work with cable modem....but it works fine with the dsl modem ....all lights are on it just won,t go through the router. do i need a different router ?
You need to reset the router settings to work with a cable modem. If you don't have the original instructions that came with the router the easiest way to do it would be to hold the reset button down on the back of the router for 30 seconds (use a paperclip or some other pointed object). After that it will just start working by itself but it will not have any wireless security set up. To do that you log in to the router via your web browser. Open Internet Explorer (or whatever you use for internet browsing), type in the address 192.168.1.1. The username and password for that modem I believe is username: admin password: (blank). It should be printed on the bottom of the router as well. Then just follow the set up wizard.
Aug 21, 2011 | Computers & Internet
Lost password--how can I reset it
You will need a paper clip to press into the hole, this will be marked in most cases with 'Reset', if not it will be placed near the ventilation holes at the bottom/back. Whilst still on, press the paper clip into the hole for 10 seconds. Then give the router a minute to restart.
Bear in mind that when you reset it, you wipe all the information on the router and you have to start again from scratch, make sure you have your broadband username/password available to hand before you do this otherwise you won't be able to reconnect to the Internet!
Aug 09, 2011 | Belkin Basic Wireless Router
All the lights on the router are working, except the wireless one. i have tried resetting it, but it just won't work.
to reset the modem, you need to atleast press and hold the reset button for atleast 10 sec to have the router resetted to its default settings.
Jul 27, 2011 | Computers & Internet
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
BLINKING POWER LIGHT WON"T RESET
A Blinking Power light on a wrt-54g usually indicates that the firmware is corrupt. You can try to wipe the firmware by following the steps below:
unplug the router
using a paper clip or pin, press the reset button
plug the router back in while the reset button is still pressed down and hold it for 30 seconds.
once you let go of the reset button the router should go through a reset. if it still blinks try the process again.
if the issue still occurs then it may be bricked.
May 27, 2011 | Linksys Wireless-G WRT54G Router
How do I reset my router password
Here is the step-by-step instruction to reset Linksys WRT120N Router
  • First af all you have to make sure the power is "On" . Power the router up while pressing the reset button located at the back of the router using pencil or paperclip
  • After around 30 seconds you will be prompted with the boot loader. Connect the boot loader using the standard IP address if you have not changed it (http://192.168.1.1)
  • Upgrade the firmware to the latest one from Cisco site
  • Power cycle the router and allow it to come up.
  • When it is fully up, press and hold the reset button for 5 secondsThe LED light will blink indicating that you're done holding the reset bottom. If the Power LED won't blink try to press and hold the Reset Button for I minute and then power cycle the router for another 1 minute.
  • Power cycle the device and now you have reset your linksys WRT120N router See the following link if you forgot to setup linksys router
(http://infoteknotainment.com/reset-linksys-wrt120n-router)
May 24, 2011 | Linksys WRT120N Router
When I type the admin in the username box and admin in the password box, it won't log in
Hi there!
the default username and password for this router is "admin" so if that is not working then you or somebody else changed the username and/or the password. you can reset the settings of your router by looking for a reset button/hole in the router. press and hold it for a few seconds and that should reset the router.
Hope this helps.
May 19, 2011 | Encore ENHWIN3 Wireless Router
NetGear WGT624 Wireless Router Logo
14 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
