Question about Cameras
I need a micro-adjustable altitude control and locking knob. The locking knob broke off in the control
SOURCE: Missing Altitude Control Locking Knob
Go to any well stocked hardware store and buy a similar bolt-- get stainless steel so it won't rust.
Posted on Jan 04, 2009
SOURCE: the Azimuth Dial isn't firmly attached cause altitude cannot be fixed to an angle
Most of the small telescopes setting circles really cannot be used to find anything--- just not accurate enough---
Try using a star chart -- and star hopping --- to what you want to see.
A free monthly star chart is available at :
www.skymaps.com
Posted on Jan 05, 2009
SOURCE: Replacement Micro-adjustable Altitude control required
You can assemble one from parts from a well stocked hardware store-- take the broken one there and have them give you a suggestion --- and
From time to time these are For Sale on astromart.com in the Misc. section ---
Posted on Jan 15, 2009
SOURCE: need replacement parts for astrolon reflector 525X
They do not sell parts for these low cost telescopes. However you might find what you need inn the bolt and nut section of a well stocked hardware store.
This brand is sold by Toys R Us--
Posted on Apr 18, 2010
Testimonial: "Thanks. We'll go check Ace or Godwin Hardware to find bolts that will compare. I read yr other advice posts;will take yr advice for a future telescope"
SOURCE: need 4 self tapping screws
You may be able to get these here by calling their service center:
http://www.opticsplanet.net/bushnell-warranty.html
Or at a well stocked hardware store.
Posted on Oct 07, 2010
Delta shopmaster. . How do i instal blade guard on Delta shopmaster?
To adjust the blade guides , you have to loosen the lock nut ( it's normal on the upper part of the guide kit, outside part). Move the guide carrrier until both bearings are approximately 1/16" behind the gullets of the blade. Release the adjusting screws to set both bearing guides to within 1/32" of saw blade by turning the micro-adjusting knob. You can then lock the bearing guide in position once the correct adjustment is reached. This works on 14" band saw. This is an instruction from the manual.
Jun 13, 2014 | Saws
I have just assembled the Tasco 70x 800 refractor, but there does not seem to be any way of adjusting the altitude. There is no knob to loosen the mount, only a nut which is hidden inside the mount which...
There appears to be a KNOB underneath that you loosen or tighten -- and also one on the altitude. Adjust these knobs so that you can move the scope but with some friction---here is the manual
http://www.tasco.com/products/manuals/SpaceStation6LIM_49060700_49070800_49114500.pdf
Apr 23, 2011 | Tasco 49070800 Spacestation(r) 70az...
Need 4 self tapping screws for altitude lock knobs
Oct 07, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
The finderscope for the Bushnel 78-9930 telescope will not align w/ the telescope. The Azimuth adjustment knob bottoms out before the alignment is achieved. Everything is molded one piece. Besides the...
Obviously the mounting for the finderscope is NOT parallel with the tube-- probably the screw holes were not drilled correctly.
This is one of the reasons why we never recommend Tasco or Bushnell telescopes. They are considered "toy" telescopes and most of them are not suitable for Astronomy.
Return it and buy one of these:
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
OR re-drill the holes so the finder scope is more parallel with the main tube.
Aug 28, 2010 | Bushnell Voyager 78-9945 Telescope
Need replacement parts for astrolon reflector 525X telescope. 1 Yoke Lockig Knob (missing) 1 screw on the yoke which is to hold the "Fine adjustable altitude control" lever. and might need to replace the...
Apr 18, 2010 | Edu-Science (10166) Telescope
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Jan 12, 2009 | Tasco Galaxsee 45-060675 Telescope
The Azimuth Dial isn't firmly attached cause altitude cannot be fixed to an angle
www.skymaps.com
Jan 03, 2009 | Bushnell Voyager 78-9945 Telescope
Nov 22, 2008 | Natural Science Industries Smithsonian 525...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
