Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
SOURCE: my homelite mighty lite edger starts, but will
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will
need to disassemble the carburetor and spray with carb.cleaner. Make
sure the small screen is free of debris.(Should be able to see daylight
through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
You may have to replace them.
If you need further assistance, just let me know.
Jim
SOURCE: The edger will not run with the choke on, even
Check your fuel filter in the fuel tank,if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
That way when you put the jets back in, you know to lightly seat them first
SOURCE: I have a Husqvarna edger
The carburetor is dirty and you will have to take it apart and clean it and all the little holes and passages. If you are mechanically inclined this is not terribly difficult.
