Question about Biostar 945GCM4 7x Motherboard
Biostar 945gc-m4 purchased new...can't get the on board video card to display anything. Powers on...and gives me a constant beeping from the mobo skeaker i've installed. can't figure out why. Also, i have nothing installed in the pci slots. no ram yet either...but, i should at least be able to get into bios with everything working properly right???
The motherboard needs RAM to operate- the beeping is the motherboard reporting unusable RAM- in this case no RAM
Posted on Dec 27, 2010
How many processors supports my motherboard p4m80-m4 biostar ? specially can it support dual core processor...??? also tell me about supported graphics card please help me>>>???
You have a very old motherboard here. It only supports the older AGP 8x video cards. Good luck finding one of those anymore that is worth the price, and don't expect anything you find to be new in box. This is probably where your HD video woes start, although the board was never designed for the higher frame rates that HD requires to be viewable.
As far as the processor goes, this board has the Socket 478 for Intel processors. There are no dual-core processors that are supported by this socket. Here is a link to an article that shows what processors are supported by the socket. Be advised, however, that depending upon the BIOS revision on the board, some of these may not work properly, if at all.
Socket 478 Socket mPGA478B
Really, if you want to view HD, it's time for a real upgrade.
Aug 24, 2016 | Biostar P4M80-M4 Motherboard
Have a replacement motherboard. After about 1 minute it powers itself off. Sometimes it does it sooner - sometimes later. Have replaced the Power supply, removed the graphics card, unplugged all...
Your motherboard is manufacturing defective. If the motherboard still under warranty, take it back to the computer shop where you purchase and demand for an exchange.
Sep 01, 2011 | Biostar P4M80-M4 VIA P4M800 Socket 478 ATX...
How to disable video on board in Biostar 945GC-M4?
When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios. Then go to advanced configuration disable onboard VGA then save settings and exit from bios. Then it will disable. Let me know if you need further assistance. Thanks for using FixYa.
Oct 06, 2010 | Biostar 945GCM4 7x Motherboard
My mobo doesnt beeps nor video output
your bis/firmware will be corupted.download latest firmware in bootable cd format and update bios.even if mb doesnot give display it can boot and flash the bios.(follow website for details on how to make cd-iso)
May 27, 2010 | Biostar MCP6PB M2+ Motherboard
My client has a p4m900-m4 mobo that was installed Oct. 2009. The system has 2 dvd players. He tried to play a dvd and the system shut off and now appears dead. I get a power light, one of the dvd players...
Hi
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or HDD or whatever as long as it's a drive) the CPU, graphics card (if required) and one bank of memory, unless the board requires dual matching chips.. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drives, make sure you set your pin settings for master/slave/CS are set correctly on it. Now, you should get the power supply on, and the cpu fan spinning. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or finally the motherboard. The next step is to replace each one of the elements with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that. I usally start with the drive, then move to the memory chip, next CPU, Last PSU. I also make sure that my replacements work on another machine first. If no change, then it's save to say you have a bad Board. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Please don't forget to leave a rating.
Thanks Mark
May 15, 2010 | Biostar P4M900-M4 Motherboard
I just bought a new Biostar motherboard. I hooked everything up correctly. But i get no VGA signal.
make sure the ram is properly installed just remove all the drive connection and remove also the ram and check it give the beeps if it gives the beep that means board is ok but something is wrong with motherboard try to swap you power supply also and check the power connector like 4 pin connector is also connected .try with resetting the bios also.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | Biostar P4M900-M4 Motherboard
I have a dell small form factor with a foxconn ls-36 mobo, upon power-up it gives me ram beep and power to fans, etc., but as far as anything else, nothing, also, mobo lights up but stays constant, no...
you could have a bad board, bad video card, bad processor, any number of things. try reseating the video card, if it is not onboard, does it post? just not enough info here to solve it
Jul 08, 2009 | Dell Computers & Internet
No Video Output.
Try without any RAM and see if there is a beep...if there is then mobo is ok. If no beeps still. Check the CPU. Also check the PSU if its giving adequate power to all the added cards. If possible try with another PSU. Try clearing CMOS as well. If all these doesn't do any good to the mobo, I think its time to RMA the mobo. Have a great day!
Jan 31, 2009 | ASUS M2N-SLI Deluxe Motherboard
Biostar motherboard or processor dead?
have you also tried different video cards? or the onboard built into your motherboard?
Jun 11, 2008 | Biostar P4M80-M4 Motherboard
Will not POST with 2g of kingston hyperX ram inside
If you are going to call. The question I would ask (Very important), will the board run with CL2 = 2.5v & or CL3 = 2.6 to 2.65volt memory.
This site is Kingston memory setter. Type in the board & it show's the type of memory the board can use. (Click on this link). As you look at the link this is for you're P4M80-M4 board.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=33018&mfr=Biostar&model=P4M80&root=&LinkBack=&Sys=33018-Biostar-P4M80-M4+Motherboard&distributor=0&submit1=Search
This should help. I did not see a bios upgrade for this board that had anything to do with memory. The USA Biostar link is lacking opposed to the global link. The global manual give far more information (In depth), for bios instructions.
Global link: http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=246
I'm sure the Kingston link will more than help you the_OCer.
Mike
May 21, 2008 | Biostar P4M80-M4 Motherboard
Biostar 945GCM4 7x Motherboard Logo
118 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
