Hi my samsung ps-42q96hd tv is making a clicking sound a will not turn on
  • 53 Answers
SOURCE: Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Posted on Mar 20, 2009
  • 60 Answers
SOURCE: Samsung ps-42p2sb Tuner never turns on.
  1. Might need a service technican to fix your set might need a new power supply or if you have any electronics backround take the back off and look to see if there are any bulging capacitors on the power supply
Posted on Aug 23, 2009
tvtek
  • 1284 Answers
SOURCE: 32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Posted on Sep 11, 2009
  • 610 Answers
SOURCE: my tv will not turn on, it just clicks but doesnt
You will need to have the power supply board replaced. This is a common problem and Samsung has re-designed the new boards so this will not happen again. You can call 1-800-samsung for the nearest authorizd service center.
Posted on Feb 26, 2010
SOURCE: samsung 52" LN52A550... tv makes
This is a known problem due to the bad capacitor(s) on its power board. Samsung will fix it for free. If you want to fix it yourself, go to Youtube and search for "Samsung clicking"...
Posted on Sep 05, 2010
Hi my tv sounds like it start but it wont como on i change the power board but still did the same what could it be thanks
Samsung 52" TV Repair - Won't turn on Clicking Sound ...
? 9:37
https://www.youtube.com/watch?v=2WpSJy_kANs
Apr 13, 2012 - Uploaded by Kathy Burton
It makes a clicking sound several times before it turns on, seems to ... Samsung 52" TV Repair - Won't turn on Clicking Sound ...Maybe it took a little longer than that, but I was happy. ... My TVworks like new. ... Samsung No Start / Clicking Repair - 52" LCD HDTV - Duration: 8:26. by clipdan 169,453 views.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and ... hi my tv flashes red and bluebut wont turn on.
Dec 12, 2015 | Televison & Video
Ps 42q96hd
The digital part? Do you mean you have sound but no picture/video? Does the power LED on the front of the TV flash? Just about every board in the TV can cause this symptom. You may need a trained TV technician diagnose it further. If you need replacement boards, Tri-State Module is a good vendor for me.
Nov 04, 2013 | Samsung HP-R4262 42 in. Plasma Television
Samsung PS-42Q96HD
Please check whether the inverter is working and giving voltage to the display board. If not, this might require attention of a qualified service technician.
Jul 12, 2012 | Televison & Video
Samsung 42q96hd shuts down starts again
Look or have someone look at the power supply first in this set for this problem, it could be elsewhere but the supply needs to be checked out first.
May 24, 2012 | Samsung PS50Q97HDX 50 in. Plasma TV
Having problems getting a full picture on my PS-42Q96HD
i have seen this before and it is the logic board failing
Dec 03, 2009 | Samsung HP-R4262 42 in. Plasma Television
Clicking noises before TV turns on.
The clicking noise is coming from the power supply relay. Is makes this sound when the TV is usually turned on or off but has become faulty. It will only get worse over time usually until the TV will no longer turn on anymore. You need to replace the power supply in order to fix the TV.
Nov 07, 2009 | Samsung LN-S4052D Television
Connecting my HP Pavillion DV9500 laptop to my Samsung PS-42Q96HD
Sound more like your problem is with the connection to the TV. Make sure the connection at the TV is to an 'input' connector and not 'output'. Also, from the TV menu, if you can select the output the laptop is using make sure the sound is stereo an not 5.1 or 7.1 or something to that effect. All other connections seem to be in good shape. Good luck.
Feb 03, 2009 | Humminbird Computers & Internet
Synchronisation problems
try to change the sound setting of your reciever.. try all options of sound setting..
Dec 27, 2007 | Onkyo TX-DS777
Optical output on tv through dvd home cinema out of sync
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
Sep 17, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
