Question about EuroCave Comfort 260 2-Temperature Wine Cellar
Thermostats are not working; unit is freezing up inside;
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
defrost timer is not working..
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Idylis 5.0 cu ft chest freezer: why is the outside of my new freezer hot to the touch, while the inside is freezing?
if new and a 5 ltr
check thermostat setting
it takes some time to freeze up unit and contents
motor will run a bit longer then normal
then should kick in on and off with the thermostat
Sep 13, 2016 | Freezers
Our house is hot! The ac unit outside comes on and freezes up, and the blower is not coming on. We have had the inside thermostat changed and freon added and now a new capasitor but no luck.....HLEp
Man, it sounds like you have a heat pump with a bad defrost board or reversing valve. I assume your description of the unit outside freezing up is the condenser and the blower you refer to is the condenser fan motor. Or, is it the big copper line to the compressor that is freezing up? If so, have someone stand by the inside blower and listen for a click as you move the thermostat fan switch from auto to on a couple of times., Make sure at the time you are testing that the thermostat is in the off position. Those 2 switches operate separately. If you hear those clicks during the test you probably have a bad blower motor if there are are no clicks you may have a bad blower relay or board. Hope this helps good luck.
Aug 17, 2013 | Carrier XHB123D X/Y Series Heat/Cool Air...
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
My freezer keeps melting andre freezing. usually it is ocurring over night. when i get up in am everything is melted and blowing 29 degree air by 1 pm its blowing -11 degree air and refreezing. Response:...
Manually turning the defrost timer will not tell you if the timer is working, it only tells you the switching inside works, The defrost timer has a motor inside that turns it through it's cycles, this would be the part of the defrost timer that stops working.
But since the unit is freezing and thawing, The problem is more likely the defrost thermostat has came loose or is defective.
Jul 20, 2011 | Kenmore 53642 / 53644 Side by Side...
{my thermostat was flashing filter} I replaced filter and now air conditioner wont kick out cold air rth230b
Remove the thermostat wires and reconnect wires after 10 minutes. Then check. --------- yellow wire on thermostat is for cooling.Disconnect the yellow wire bolt remove yellow wire and then see if AC works will yellow wire unplugged..If its works that means the Thermostat is the issue.It has to be replaced. On some newer honeywell thermostats.there is blue wire instead of yellow wire.The connection is same, but blue wire is there instead of yellow wire.In that case disconnect blue wire and then see if AC works with blue wire disconnected. ---------- Check this.This will help.Thanks.Helpmech.
Jun 07, 2011 | Honeywell Heating & Cooling
Fridge leaking water inside.
Check frosting over would have clogged the drain pan. Unplug unit and wait for sometimes until defrost is over. Then run the unit. Please confirm, defrost timer,thermostat and heater are working properly to get auto defrosting time to time.Thanks.
Jan 30, 2011 | Samsung RS2534 Side by Side Refrigerator
Coleman Heat Pump Freezes Up
This sounds like an airflow problem. You said you change the filters every 3 weeks or so. Check the filters and the indoor coil to make sure they are clean. Also look at the indoor fan and make sure it is running and running at speed. A fan that isn't running at the rated speed will cause the coil to freeze. A weak capacitor can make the fan run slow. Also make sure the fan blade/wheel is clean. A low refrigerant charge will also cause the unit to freeze. It doesn't matter what you have the thermostat set on because the temperature of the refrigerant is determined by the pressure of the refrigerant and the airflow across the coils. If it freezes up again you can put it in heat mode to melt the ice.
Jun 23, 2010 | Coleman Heating & Cooling
I have a blinking snowflake icon on my air conditioner, my air will not work. My heater will work fine but the air will not come on
When the snowflake is blinking the thermostat in in a delay mode designed to protect your compressor. If it does not stop blinking in 15min the stat is bad otherwise something is wrong with the AC
Sep 26, 2009 | Honeywell Electronic Programmable...
The unit is not cooling. have noticed ice on the line in the unit outside.
if one or few pipe may not aproblem may be the thermostat is aet to very low cool anf the fan on low speed or the thermostat is defective also if this icing is growing up means
-1 evaporator need cleaning
- 2 a smll freon leakage
May 04, 2009 | Heating & Cooling
Refrigerators Logo
287 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
