Question about Kenmore 64212 Electric Dryer
Dyer starts and runs but does not heat - Kenmore 64212 Electric Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Sep 11, 2010
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Heating problem
There is a thermal cutoff built into the dryer to protect from fires due to overheating. This could be activating after the dryer starts running for a while. Is it possible that the exhaust duct is clogged up with lint? Check the airflow at the dryer vent.
Dec 17, 2013 | GE DCVH515GF Gas Dryer
Kitckenaid dyer KGYe6778WH1 Dyer won't heat
This is most likely due to the coils on the gas valve, they can become unstable and cause the symptoms you are describing. The coil kit is part number 279834 and runs about $20.00. It is replaceable from the front and not too hard to do.
Side note: the '8' in your model number is actually a 'B'
Apr 22, 2010 | KitchenAid KGYS850LT Gas Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
My dyer will not cut off
I would suggest checking to see if your start button is stuck
Jun 17, 2009 | Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer quit heating up,timer doesn't work,this happened all at one tim
no dyer run's just does not heat up,timer never move's,which I think need's too for dyer too heat up,i could be wrong,just happened all at one time
Aug 03, 2008 | Dryers
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Kenmore 64212 Electric Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
