Question about Dryers
My whirlpool dryer model number LER5636PQ0 suddenly stopped working. Push to start button does not do anything. I know it's not the outlet since I plugged in another dryer and that one works fine. In what order should I troubleshoot for problems and how do I do these?
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
rickzilla
  • 706 Answers
SOURCE: Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
Posted on Sep 11, 2008
  • 91 Answers
SOURCE: I have an Estate Whirlpool
motor needs to replaced
Posted on Jan 03, 2009
SOURCE: Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Posted on Jan 26, 2009
SOURCE: Dryer won't start - Whirlpool LER7646EQo
update: I put in a Thermal Fuse Part # 3392519 and we are spinning again! The part will cost about $14.00.
Posted on Mar 10, 2009
I PUSH THE START BUTTON AND HEAR A BUZZING NOISE THEM STOP
t is very important that you give all the details possible, such as what the dryer is doing, what you have tried, approximate age, and most importantly, the model number dryers the model number will be located inside the door jam. On some dryers the model number will be located on the back of the back-splash at the top. You shouldn't have to pull the dryer out to see the model number.
Dec 16, 2010 | Whirlpool LER4634J Electric Dryer
My whirlpool dryer start when you press the start button - but as soon as you stop pussing the start button the machine stop and does not continue on it self.
This problem is most commonly due to the motor. The motor has an internal switch called a centrifugal switch that senses when the motor is up to speed.
The second cause could be the start relay (this is present on some but not all models), this is part of the start button you push and is less expensive than the motor, it can be checked with an ohm meter to determine which component is faulty.
If you can send me your model number I can pull up the wiring diagram to determine which type of start component is on your Whirlpool. The model number can be found on the tag just inside the door
Jul 28, 2010 | Dryers
My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Apr 08, 2010 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer LER5636PQ0 push to start keeps failing to work
You could have a worn door switch . Push in on the plastic piece which closing the door actuates and press the start botton . If it starts ,several times , then replace the door switch . Pt # 3406107 . Do this after you put the 2 thermal fuse (slim white piece with 2 wires attached )wires togather for testing purposes only . BE sure to unplug dryer before doing ANY repair testing first ! If it starts by jumping the wires , then pt # 3392519 fot thermal fuse .
Jul 14, 2009 | Whirlpool Dryers
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Electric Dryer stop working
could be a bad motor , or the starter on the motor.?? if you can hear the motor running then go for a new belt..
Jun 13, 2008 | Dryers
Dryers Logo
134 people viewed this question
Top Dryers Experts
