Question about Compaq Armada 1700 Notebook
WONT POWER ON AND LIGHTS ON FRONT FLASH - Compaq Armada 1700 Notebook
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
What do flashing lights on the front mean?
ever consider paying a repair place to fix.
Jan 16, 2015 | Televison & Video
Corner lamps wont flash on1991 nissan stanza
Have you tested the Flashers for continuity?
May 10, 2014 | 1991 Nissan Stanza
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
2001 tp cruiser turn signals wont flash
check the flasher relays in the fuse box. these are what causes the lights to flash.
Feb 11, 2014 | Chrysler Cars & Trucks
Pulls to the right and stops and wont go and the control lights flash on and off
What are number of lights and colors? Check motor connections to controller. Is it freewheeling?
Mar 16, 2013 | Pride New Jazzy 600 Power Wheelchair by...
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
My left flasher dont work,can younpls help?
it would help to tell what its doing or not doing... front? rear?comes on, wont flash, both rear brake lights work? running lights? right side works OK? turn the hazard flashers on and look at what bulb isnt flashing and start with replacing it. If that doesnt work, make sure power is on the wire to the bulb.
Dec 05, 2010 | 2005 Chevrolet Silverado
The tv wont turn on the lights in the front of the tv all stay on the red and two greens and when you try to turn on the power the lights just flash and the screen stays black
That is indicating a internal defect. It's likely you will require a shop repair. Contact the manufacturer with the model number and ask for a referral. The flashing lights indicate that the television is telling you there is a failure someplace in the internal circuitry.
Mar 30, 2010 | Televison & Video
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Compaq Armada 1700 Notebook Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
