Question about Medion MD 96340 Laptop
Laptop keeps freezing, sometimes within minutes of turning it on. Did this once before and someone fixed it for me by installing updates I think and it was fine for about six months. My computer appears to be up to date.
Most likely the heatsink is clogged with dust. If you're lucky, there is a cover on the bottom that you can remove. You should be able to see the fan through the slots. If not, then the whole laptop has to be dismantled, clean out the dust and reassemble. This is not a trivial job. This is why I like Lenovos, they give good access to the processor so you can clean or change it. Most other manufacturers do not.
Posted on Nov 29, 2010
Toshiba laptop frozen pointer mouse
  • If you're having problems with Windows Update, make sure you're connected to the Internet, and then download and run the Windows Update Troubleshooter for your version of Windows.
  • Download troubleshooter for Windows 10
  • Download troubleshooter for Windows 7 and Windows 8
  • After the troubleshooter finishes, try running Windows Update again and install any available updates.
  • Or,
  • https://support.microsoft.com/en-us/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness-tool
  • Mar 15, 2017 | Computers & Internet
    My laptop will just randomly turn off...it will run well for a few minutes and then just turn off and everytime i try to start it over it turns off even quicker...within a minute or two...i realy need help...
    Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
    2- Repairing and cleaning Windows registry.
    These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
    The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
    When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
    Nov 02, 2010 | Acer Aspire 5315 Notebook
    I have a Sony VGN-FW17)J... It started freezing occassionaly about 20 minutes after stratup. A reboot would fix it and it ran fine. Then it would freeze minutes after bootup and restarting wouldn't help....
    Probably has a dead fan inside and this is causing it to overheat. You will have to take it apart and replace the fan. To test if it is heat related spray duster or freeze spray inside it to keep things cool.
    May 05, 2010 | Sony VAIO VGN-FW170J/H Laptop
    Vaio VGN-FZ340e freezes without reason!
    Possibly you have a programme running in the background that is causing the freezes, could be a screensaver. i think at sometime microsoft will issue an update that will fix this problem.
    Oct 15, 2009 | Sony VAIO VGN-SZ460N/C Notebook
    POWERS UP BUT THEN FREEZES AFTER ABOUT 4 MINUTES
    Need to test and isolate where it exactly freezes? After dell logo, after windows logo or while inside windows? Now, if it only freezes inside windows try to turn off your windows updates and antivirus first and check if still freezes, if yes then try booting in safe mode, reboot system then keep tapping on f8 once dell logo appears. Check if laptop keeps freezing in safe mode. Please let me know.
    Oct 01, 2009 | Dell LATITUDE C600 PIII 750MHZ 128MB 15GB...
    I have a new samsung NP-R60Y laptop running on vista home premium and it keeps freezing up, this could have in the first 10mins of switching it on or within 3hours, tried removing recent software and...
    If you have the recovery cd, boot your laptop with the recovery cd in it and follow the screen and recover your system to factory settings than it should be ok.
    Aug 19, 2008 | Computers & Internet
    Autoamatically loading loudspeaker option and multimedia utility.
    I think your phone may need a Software/Firmware update. Before doing that, try resetting the phone:
    Take your SIM card out.
    Make sure your phone battery is fully charged.
    Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
    Give it time to reset.
    Yes! I know. You need someone to press the ON button.
    Then update the Software (sometimes called Firmware) thus:
    You need to download the latest Nokia PC Suite to do an update on your phone.
    Before updating software you should check that there’s a newer version of software available.
    WARNING
    When updating software on Mobs, be sure to:
    HAVE A FULLY CHARGED BATTERY INSERTED;
    PUT IT ON GENERAL PROFILE;
    TURN OFF YOUR PIN NUMBER;
    CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
    DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
    THIS CAN TAKE 30 MINUTES OR MORE.
    And obviously don’t unplug the phone from the PC.
    Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
    It is also wise not to use your PC while updating software, just in case the PC freezes.
    If the PC freezes during an update, you’re up the creek without a paddle...
    I did an update on a Sony Eric 810i it took nearly two hours.
    More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
    May 27, 2008 | Nokia N70 Cellular Phone
    My ps3 freezes up and colors just start covering my screen after its on for about 20 minutes
    unfortunately there is no quick fix i had to phone ps3 and get a new one they were really good about it explained what happen and it is a problem with them i phoned up on the monday and they sent out a new ps3 next day u have to do a swap they give u new one and take the old in one go the number is on the ps3 website customer service. hope this help and hope u get it sorted.
    Mar 18, 2008 | Sony Playstation 3 (PS3) Console
    Garmin c330 freezing
    I am happy to say my problem seems to have been solved. I found 3 possible solutions during my search - may need to try all of them to see if it works. 1) Reset by pressing the button under the faceplate. (Did not work for me). 2) Master reset - switch off the unit and press on the right bottom corner of the LCD and switch it on. Release the power button when it powers on, while pressing on the R lower corner. This is supposed to erase all prior data. I could not master reset my unit, for whatever reason. 3) Software update: http://www8.garmin.com/support/collectio... If you are a windows user you will want software version 2.4.1 as of April 3 2007. This worked for me. Thanks.
    Sep 22, 2007 | Garmin Nuvi 660 GPS Receiver
    Medion MD 96340 Laptop Logo
    111 people viewed this question
    Top Medion Computers & Internet Experts
    Larry Chandler
    Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
