Question about Kenmore Ovens
The right front burner is not working. is there fuses some where to check I am not sure were to find the model #. The only # I see on the stove is 31808660 revg
2 Suggested Answers
  • 13 Answers
SOURCE: Front right burner on GE glass top range not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Posted on Jul 24, 2010
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
I have a 4 burner Frigidaire gallery stove with electronic ignition. My front right burner does not light. All other burners light. I understand that if water gets in the actual burner (hole?) while...
You can remove that one burner usually fastened with one screw.Check that all holes are clean and not blocked.If you do wash the burner make sure to blow it off with compressed air.You can also dry thoroughly.
Feb 02, 2011 | Ovens
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
My front left burner on elec.range model FEFL67GCA does not work.
If it's just quit all of a sudden then I assume it's burned out.You will have to remove the glass top to get to it. The new burner has two wire connectors that plug in. CAUTION: Make sure you disconnect electrcal power to the stove before working on this!
Apr 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Indicators lights come on
First thing to check is to put your hand over the burner when the indicator comes on and see if the burner is actually hot! DO NOT actually touch the burner! The smell of your own burning flesh is not so pleasant, and could cause you to pass out with your hand still on the burner or something like that, so be careful. More than likely, the problem is with the burner switch, but could be with anything between that and the actual element.
What did they quote you $350 to repair???? Was that parts and labor, or just parts? Sounds very high. If, however, you have one of the older stoves with a ceramic top that had the element in the top, you have to replace the whole thing to fix one burner, not very smart, economically. Newer stoves use seperate elements beneath the glass top, and so are much less expensive to repair.
Go to the Sears.com website, and click on the parts link (it's in a line of grey typed links, relatively small font, a couple of inches below the top of the website home page, and toward the right side.) Type in your model number on the right side of the parts page where it says to, and it will come up with a parts breakdown that has a list of the parts and their prices. If they never sold your model, you might have to come up with a similar model that they did sell in order to get parts listings that would work.
That will at least give you an idea of prices. You should also look at the switch for that burner.  If the burner won't run on either size setting, I'd suspect the switch or that the power is not getting to that switch.
Remember, you are working with 220 VOLTS here, and be very careful. But if you can handle a voltmeter, you can determine if power is getting to the switch, and getting out of the switch, and if it is getting to the element. You can buy a DVM at Radio Shack or Sears, or just about anywhere else, these days. Elenco is a company that makes decent ones very cheaply, and you can buy them online. Or you might have a friend or relative who has one at home, and knows how to use it around 220 volt circuits....
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
