Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like it does when you cover the hose with your hand
  • 694 Answers
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Posted on Sep 12, 2010
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Also, the high pitched "whine" could be the little flap on the filter bag when you replace it. Remove the flap, re-install the bag and see what happens. It could be just that simple.
Posted on May 13, 2014
Where are locking keys on old electrolux canister vacuum #2100?
not sure what you mean, I assume you are trying to access the inside.Oneach side of the machine there are sliders. The long rubber deal on the sides.Theses slide out..be careful and make sure the machine is unplugged....
Jul 14, 2014 | Electrolux UltraLux 2000 Bagged Canister...
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
How do you open the back of the canister to get the fan and motor out
You can't take the back off. You have to separate the top and the bottom of the canister. The screws are on the bottom. Once the machine is apart, all interior components are easily accessible. Be careful when you re-assemble it not to pinch any of the wires that run along the side.
Feb 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Where is the filter on an electrolux canister and how to you change it.
This model has the filter beneath the tools/attachments.
Open the hatch to gain access to the tools. Release latch/tab at the front of the tool holder, and lift. Remove and replace filter. This should be done every 6 bags.
For additional information, check your manual, or download one from the below link. The Guardian will be listed under "older models".
Dec 12, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
The engine makes a funny noise and the brushes make sparks.
Hi
The bearings are not replaceable. If the bearings have gone you need to replace the complete motor
Mar 09, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Roaring vacuum
Good day,your problem seem that it is plug if you have no suckiong ,place the hose on the exaust that should un plug the hose,or the motor has had some dirt et it and plug the intake ,that is why it roars try this,later
Aug 08, 2008 | Electrolux UltraLux 2000 Bagged Canister...
No power to vacuum motor. Switch need to replace.
See my response to "posted by bigbadben on Oct 07, 2007".
The cover that I referred to in my answer is a small plastic plate that covers the 'live' electrical bayonets between the electrical cord rewind spool and the motor. I did not make this clear in my first response. Before you start disconnecting any wires take a digital photo and/or draw yourself a electrical diagram. Save yourself a lot of time come reassembly.
Jan 02, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
657 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
