Question about Healthometer Health o meter Body Fat Fitness Bfm884dq 60 (Health O Meter)
Change pounds to kilos on healthometer scale model bfm790dq-05 a301bn--how is it done?
I want to change the time and date on healthometer scale
Google (healthometer)(model)(manual) without parens to get instructions.
Jan 25, 2017 | Healthometer Health & Beauty
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
The scales double my weight
Are you using kilo or pound, because an English pound is lass then half a kilo.
That could make the difference.
Jan 19, 2015 | Cars & Trucks
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
Weighing klo and not pounds
Look for a switch on the scale on the bottom or sides and slide it to the lb. side.
Jun 19, 2014 | Taylor 5599 440 Pound Tempered Glass Body...
How do I chane te ealthometer scale from kg to pounds
Search the equivalence in the dictionary and make one scale, and MARK your Healhometer
Jun 21, 2012 | Healthometer Digital Scale
Beurer Personal Diagnostic Scales BG 65 User Manual,
I had to change the batteries in my beurer scale and now i cant the the scale to register in reg pounds just kilo's?????
Sep 01, 2010 | Health & Beauty
Need a manual to find out how to set the scales back to pounds
I'm afraid I can't tell you how to re-set your scales, but these days the UK is part of Europe, and like it or not, we all need to get used to thinking in kilos (and, for that matter, in metres instead of yards).
1 kilo = 2.2 lbs. So all you need to do is to take the kilo figure and multiply it by 2.2 to get your weight in lbs. So if, for example, your scales show 60 kilos, multiply that by 2.2 and you get 132 lbs.
Jul 14, 2009 | Soehnle 63700 Calando Quattrotronic Scale
Need to change lbs to kgs
well if u cant change it you can always calculate it 2.5 pounds=1 kilo so if you have 2 kilos it would be 5 pounds and if you have pounds and want to make it to kilos u take the pound amout and divide it by 2.5 so if i have 25 pounds that is 10 kilos
Apr 30, 2009 | Computers & Internet
Healthometer Health o meter Body Fat Fitness Bfm884dq 60 (Health O Meter) Logo
469 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
