Question about TallyGenicom 6312 Matrix Printer
How to you know if your new Tallygenicom printer 6312 is compatible to your system?
    Novelist:
  • 169 Answers
The answer to this depends very much on what sort of system you are using......
If it is a Windows System you can simply install the Windows Printer Driver and use the printer as a normal Windows Printer.
On Unix / Linux you can set the printer up (usualy using CUPS) in this case you can use one of the standard device types and select a corresponding emulation on the printer-
Set the printer to Epson FX emulation and use a Epson 9 Pin printer driver
Set the printer to IBM Proprinter emulation and use an IBM Proprinter priver (9pin)
On the AS400, iSeries, Seriesi you can also use the Epson FX emulation or IBM Emulation and select the corresponding device type on the host system
Other systems may support similar functionality.
You can also send plane text files to the printer, or alternatively program you own escape commands to control print features.
So like I say it depends on the system you are using, perhaps a good place to start is by contacting Support for the Computer Application or System you are using to see if they support Dot Matrix and or Line Printers.
It is not possable to give a generic "Covers all Systems" answer, unfortunatly
Posted on Mar 30, 2011
Not print in windows xp from lpt1
There are two likely issues. First, install the appropriate drivers for the printer from here... http://www.tallygenicom.com/products/productdrivers.aspx?id=5976. If that doesn't solve the issue, the LPT port may be disabled in the bios of the computer. To solve it, enter the bios and enable the LPT port. (Normally under "Integrated Peripherals"
Oct 29, 2013 | TallyGenicom 6312 Matrix Printer
I want pdf menual 6312 line printer
can send email to attach pdf for tallygenicom 6312
Oct 26, 2012 | TallyGenicom 6312 Matrix Printer
Paper out prolems end solution for TallyGenicom 6312
try no align sensor of paper in pack left of platen
Jun 15, 2012 | TallyGenicom 6312 Matrix Printer
Sir, We have a Genicom 6312 L Line Printer. This printer is attached with UNIX (5.9) system. It was working fine till few days back. Recently we changed the Logic Card. After this the printer is not...
If the printer does not print from Unix via parallel interface, it may be nessesaey to set the BI-DIRECTIONAL setting within the Parallel interface settings to OFF.
Sep 21, 2011 | TallyGenicom 6312 Matrix Printer
Printer TallyGenicom T6312 printing blank pages
This is most likely caused by a problem with the print gap mechanism. It seems the print gap sensor was not able to adjust the gap correctly for your paper. The first I would try is to update to the current firmware version (4.0A) which is in many times solving the problem. If not you would need to replace the print gap sensor.
Sep 27, 2010 | TallyGenicom 6312 Matrix Printer
The print job for the TallyGenicom 6312 is a coupon and has a barcode in it, and the barcode is not readable by the barcode reader. The printed barcode looks perfect. And, the barcode reader has no...
Try to adjust the "Bar" setting in the Graphics menu. Here you can specify the density of the barcode. I have seen the best results using the Medium setting.
Jul 12, 2010 | TallyGenicom 6312 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Showing error hammer voltage 1
This error indicates that there is most likely an issue with the Hammer Driver's you may need to replace the logic board.
I would however try upgrading the firmware to the latest version, I think this is version 4.0 as I believe this may contain some fixes for Hammer Voltage errors.
Jan 13, 2010 | TallyGenicom 6312 Matrix Printer
NEW PLATEN FOR TALLYGENICOM 6312
I would recomend you ensure the printer has the latest firmware as the way the pritner deals with platen problems has changed. I belive the latest firmware version is version 4.0.
The platen can be calibrated with the Technical Access Menu.
The Technical Access Menu is enabled by holding down the LINE FEED and ENTER buttons for 5 to 6 seconds until the printer flashes up Tech Access On.
The menu path to the Platen Calibration is;
TEST>DIAG>CAL ENGINE>PLATEN, then follow the instruction on the display to remove the paper and ribbon etc
Jul 12, 2009 | TallyGenicom 6312 Matrix Printer
Out of paper
If you click this link, you will find the exact solution to this problem (at ae.talligenicom.com).
http://www.tallygenicom.com/support/technotes/gen_t/gen_t_040.htm
If you need further assistance, please post back, otherwise thanks for rating FixYa!
May 28, 2008 | TallyGenicom 6312 Matrix Printer
TallyGenicom 6312 Matrix Printer Logo
195 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
