Question about Apple MacBook Mac Notebook
Computer freezes after about 5 min of use, with the rainbow twirling. Have tried apps/util/ repair and still the same prob. Have a MacBook.
  • 863 Answers
Click on the apple icon at the left top corner of your screen and then click on about this mac. Then select more info. Now select the Memory and look on the screen to see if the status is "OK" for both RAM chips. Spinning wheel of death means something is wrong with the RAM chips. Take the RAM chips out and replace them with new ones or take them out and re-seat them and see if that helps. If that don't help, then select the "system preferences icon". Click on accounts under the system title., select your icon account, then click on login items, and then select all the items on the list and click on the minus button to get rid of them. Then restart your computer to see if that don't help any. All these login in items are not needed and slow down your machine a lot. Your not actually deleting the programs-your only removing them from the startup files. So don't be scared. If that don't help, then back up your files and re-install your OS. If that don't help, then your SOL and you got to see the expensive Apple tech and have them put in a new logic board for ya.
Posted on Oct 06, 2010
Why does my Macbook Pro freeze?
When does it freeze exactly? When you are running an app or is it a sleep/awake failure?
Without knowing this, I will suggest the following:
Start by making sure you have the latest software updates. After that, go into your Applications, then Utilities and click on Disc Utility
Click on your drive then click on Repair Disk Permissions.
I hope this helps stop the freezing.
Jun 08, 2015 | Apple MacBook Pro Notebook
Dashlane desktop app quit unexpectedly on Macbook Air?
Dear friend,
Try to Repair Permissions on your Mac.
Go to Applications, Utilities, Disk Utility, Fist Aid, select your partition under your hard drive, and click Repair disk Permissions.
Sep 03, 2014 | Computers & Internet
Apple Macbook pro beeps 3 times then freeze with I open Google drive app
First try clicking on your desktop, then Go menu (at the top of the screen), then Utilities, then double-click Disk Utility. Select your hard drive on the left, then you should be in the First Aid tab/pill on the right, then click the "Repair Disk Permissions" button (and restart for good measure when it's done). If it the only app that does this, maybe delete it and get the newest version?
Troubleshooting can be tedious and not usually one question/one answer; perhaps the easiest path to your fix is to backup your data (use Time Machine or just copy what you want to keep; if you don't have a drive, spend the $100 via Amazon slash dp slash B00CGUMS48).
Once you have your data, clean slate your Mac (boot to the system DVD or USB that came with your machine; or, you can just get Maverick (which you can download, but not install (leave in Applications), then connect a 8GB USB stick (Amazon B00DYQYJ3Q) that *doesn't* have data that your care about, then run a command in Terminal: sudo /Applications/Install\ OS\ X\ Mavericks.app/Contents/Resources/createinstallmedia --volume /Volumes/THENAMEOFYOURUSBSTICKHERE --applicationpath /Applications/Install\ OS\ X\ Mavericks.app --nointeraction).
Hopefully makes sense, and clean slate may not fix (but should, just install the faulty app and run it); so, that would mean something like faulty memory (where a strong program might dip deep enough to manifest), but clean slate is a wonderful thing.
Apr 10, 2014 | Apple MacBook Pro Laptop Computer with...
When i turn it on it wont stop loading and after about 10 mins it turns off
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
Try running a Disk Repair with Disk Utility using your Mac OS X installation disc or restore disc (which came with your Macbook)
font.f1 {font: 13.0px 'Myriad Pro'}
-RUN DISK UTILITY WITH STARTUP DISK-
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
See if that process helps bring your Macbook up to the normal desktop.
If it does not, use the SMC reset procedure.
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect the AC adapter and remove the computer's
battery.
• Press and hold the power button for 5 seconds and then
release the button.
• Reconnect the battery and AC Adapter.
• Press the power button to restart the computer
This should help resolve the issue for you. If it does not however, just let me know.
Thank you.
Regards,
Mactechtrainer
Feb 04, 2011 | Apple MacBook Mac Notebook
Our MacBook doesn't do anything but stay on a white screen that just shows that apple going around in circles in the middle of the screen.
You got the rainbow spinning wheel of death, which means take out the RAM chips and re-insert. Now try. Nothing? Replace the RAM chips with RAM chips you know are working. Now try-Nothing? Install disc one of the install disc Apple gives you and go into the system utilities and repair disc permissions and also click on repair disc after that. Now try-Nothing? Replace the hard drive and re-install the OS. Now try-Nothing? Your fu.kd my friend, which means you got a logic board problem.
Sep 04, 2010 | Apple MacBook Mac Notebook
There is a small little coloured ball that comes on my computer and then it freezes while I am playing a game
Thanks for contacting Fixya Support.
Anytime you see the "rainbow pinwheel" which does manifest itself from time to time in Mac OS X environments, this is an indication of either a software issue or even a hardware issue.
Considering you are playing a game, it would be safe to assess that this issue you are having is in relation to the game you are playing (being unresponsive), means that this is a software issue.
There are several variables in regards to fixing issues with the spinning pinwheel in relation to a software.
If your application is not responding, you can first of all Force Quit the application by selecting Apple Command, Option and the Esc keys, and either select the game application in the window, which should be displayed as "Not Responding" and Force Quit or select Finder and simply relaunch it.
If you are unable to get your Mac OS X system to respond at all, then try a PRAM Reset process as shown below:
--PRAM RESET --
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
This should help with the freezing issue:
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Macbook to start up.
--Check to see if you are able to launch and play your game now.
If neither of these steps work, then if you have your Mac OS X installation disc which came with your Macbook, then I would finally recommend you perform these steps below with the installation (Macbook Restore) disk:
-RUN DISK UTILITY WITH MAC OS X INSTALLATION or RESTORE DISK-
Insert your Mac OS X Startup disk (Note: make sure the disk contains the same Mac OS X platform that your Macbook is currently running)
•Reboot your Mac
Now attempt to run your game application and see how your system responds after the Disk Repair process.
If the Macbook still persists in freezing or the game application still causes the spinning pinwheel to appear, then you may need to increase your Macbook's RAM memory, as the game may require more memory resources than you current have installed with your Macbook, or it may not be compatible with the current version of Mac OS X you are running with your Macbook.
I hope these steps point you in the right direction.
Regards,
-Mactechtrainer
Aug 20, 2010 | Apple MacBook Mac Notebook
Cannot eject flash drives. Closed all apps and tried Disk Utilities.
How did you try to eject the disc?
Drag it to the trash or Command E or put away?
You may need to repair your permissions on your main hard drive.
Apr 29, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Slow start up and overall operation
you can try to launch disk utilities (/applications/utilities/disk utilities.app) and repair disk and authorizations
Apr 13, 2009 | Apple iMac G4 Desktop
Freezes at start of game
This is a problem with the games. Check the back of the CDs for scratches. Try to compare them with games that work. If you see a noticeable difference you can buy a CD cleaner from gamestop and remove the scratches from it .
Feb 18, 2009 | Microsoft Xbox 360 Console
My 360 keeps freezing
No red lights? Do you have your system properly vented? If you own an older system you may want to consider purchasing a cooling fan. Also some games are known to have a freezing glitch "Ex: Rainbow 6 vegas 1" If the games are freezing all the time after just 10 minutes that sounds like something you may want to contact Microsoft about repairing
Jun 07, 2008 | Microsoft Xbox 360 Console
Apple MacBook Mac Notebook Logo
108 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
