Question about Kenmore Washing Machines
My washer filled up with water during regular beginning cycle and once fill washer just stopped. I feel like this happened before and it was something that may have gotten stuck in the drain??.....I move the dial to other settings, and doesn't do anything.
  • 905 Answers
Hello LazyOne
The motor is locked out until the water level requirement is met. The level selector switch is probabably having issues, try rotating it back and forth between small / medium / large loads. If it starts to fill on larger load sizes, it will be the switch itself. If it doesn't do anything at all, it could be the switch, but most likely it is the level sensor. Both are located in the compartment behind the controls panel.
Posted on Sep 10, 2010
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Kenmore dishwasher has loud noise during fill. If you let it go, the washer fills. Once filled, noise stops and wash cycle continues. Sounds like plumbing does when there is air in the pipes. Not a...
This isn't a solution but rather a comment, if the problem is happening only during the fill, then it could be the water inlet valve. Perhaps there is a soliniod going in the valve, watch to see if the fill cycle starts to dimminish over time. Does the sound come anytime the washer fills, ie: rinse cycle? if so I would replace the valve, probably 50 dollars would get you a new one and you can do it yourself to save a little more cash. good luck.
Apr 19, 2009 | Kenmore Dishwashers
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Washing Machines Logo
46 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
